HP 15-dy0008ca WHITE Screen
  • mferna14
    • Jun 2018
    • 1045
    Hi All., Does anyone have the BIOS files for this model Hp 15-dy0008ca, motherboard # DA00P5MB6D0 REV D... I am uploading this Original Bios dump for this model, if someone can repair this file. I am getting a blinking white screen no other activity. Thanks in advance
  • peste
    • 13430
    • ROMANIA
    Re: HP 15-dy0008ca WHITE Screen
    try..
    • mferna14
      • Jun 2018
      • 1045
      "PASTE" thank you so much.. all works well.
      • mferna14
        • Jun 2018
        • 1045
        This BIOS which I posted uploaded 100% works.. Tested on the motherboard today & all works fine. Kindly use when possible.
        • kingkong computers
          • Sep 2018
          • 210
          • pakistan
          need 100% woking bios my file just blinkin capslock
          • peste
            • 13430
            • ROMANIA
            have you tried post # 2 ???
            • mferna14
              • Jun 2018
              • 1045
              I told you that all works fine there after.. thanks
              • harp
                White screen repairs
                by harp
                To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                05-13-2024, 03:43 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • EazyBone
                Sharp LC-65Q620U White Screen
                by EazyBone
                Another TV topic!!
                I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                08-21-2024, 12:56 PM
              • hcinne
                Dell G15 ryzen edition black screen 2 amber 1 white
                by hcinne
                I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                07-23-2024, 07:56 AM
              • Chrissygizmo
                Panasonic TX-48CX350B backlights but white screen , blank screen
                by Chrissygizmo
                Hi all, I’ve got a problem I hope someone can help me fixi.
                I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                01-11-2025, 03:18 PM
