Re: Dell G3 15 3500 bios help
Please, can you help to repair my bios
It was water, now the mb is clean and repaired, but Bios beeps speaker 1time in 5-10sec and no picture
Dell g3 15 3500
service tag: B6B4003
board: selek g3 mlk n18p 19795-1 403yf$la
Its not very clear what you mean by clear .Please read the rules
Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
.Leave a comment:
hereAttached FilesLeave a comment:
Can you please, clear this bios for Dell 9BWS403Attached FilesLeave a comment:
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
https://www.badcaps.net/forum/showthread.php?t=103570Leave a comment:
Hi BRO, can pls repair my bios? It speakers 1 time in 5 secondsLeave a comment:
Read the rules before posting:
.Leave a comment:
.Leave a comment:
bios not working, I tried other bios and it worked but it didn't save the service tag! help...Attached FilesLeave a comment:
It didnt work. Same condition service tag not saving and showing Alt+F manufacturing mode error with fan at high speed always. Please help to atleast remove the manufacturing mode error and fan to work at normal speed.Leave a comment:
I am also facing same problem the service tag is not saving and manufacturer mode unable to exit.
service tag : FQB6ZZ2
Pls helpAttached FilesLeave a comment:
Hello everyone. Please look at what's wrong. And correct my old bios
SERVICE TAG 3DYWZZ2
thanks in advanceLeave a comment:
Service Tag: 414TM93Attached FilesLeave a comment:
try to reprog the two chips with the file 1
the laptop will be stuck on manufacturing mode and can't save the service tag
then reprog only the 8mb chip with the file 2, you will can save your service tag and it quit the manufacturing mode.
inform us with the result. thnks
dear Sir
same problem i am facing the service tag is not saving and manufacturer mode unable to quite
service tag :414TM93Attached FilesLeave a comment:
Dell g3 3500 19795-1
bios writed but gives service tag error
servİce tag-dygt663
help pleaseAttached FilesLeave a comment:
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
