100% ok thnak you
Dell G3 15 3500 bios help
Hello, help motherboard: selek g3 mlk n18p 19795-1 when connecting, only the keyboard backlight turns on and it restarts. That's all it does without an image, without fans, it just cycles through the reboot, turning only the keyboard backlight on and off.
CPQK463 service tagAttached FilesLeave a comment:
did you try to add service tag manually from bios setup ? if not than add your service tag in the bios setup problem should resolved
if yes and problome remain same than
Flash 8MB only from #131 and use your 16mb old
Can you tell me what it could be?
ThanksLeave a comment:
Hello. Can you help me? I have the Dell G3 3500 P89F002 notebook. It only shows video the first few times after resetting the bios. But it turns on and the video appears the same as the attached image, the fans are at maximum and when you click to enter the setup it restarts without video and the orange and 7 white LEDs (LCD) blink twice. I switched to the 8mb and 16mb bios from the last post by member "kostukas1985" and it worked but it keeps giving the Service Tag message.
My Service Tag is 3JWR8G3
Thanks.
Flash 8MB only from #131 and use your 16mb oldLeave a comment:
Thanks.Attached Files2 PhotosLeave a comment:
❤️Extarnal link not allow❤️
https://www.badcaps.net/forum/showthread.php?t=103570Leave a comment:
He you go. 100 % working bios with service tag add and manufactoring mode disableAttached FilesBadcaps Electronics Repair Forum & Schematic SearchLast edited by Vesko356; 02-25-2024, 04:08 AM. Reason: External url removed. File attached to post from external link.Leave a comment:
gratitude worked, being able to add the normal tag thank you al l
What does it mean? What exactly is the issue? Where's your bios backup?
Do NOT post in all caps!
Read the rules before posting
You MUST:- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Service Tag: CM191B3
Try with new build
Flash both
Wait few minute after program file
Must check with heatsinkLeave a comment:
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
