Dell G3 15 3500 bios help
  • Arsalan455
    replied
    Originally posted by RJ_TECH
    Service tag. DZHT663
    Build New try and report
    add new service tag in bios
    100% ok thnak you
  • lalodbs
    replied
    Originally posted by Markus1741
    Hello try this new file ...
    thank you so much. but it didn't work for me, it has the same error
  • Markus1741
    replied
  • lalodbs
    replied
    Hello, help motherboard: selek g3 mlk n18p 19795-1 when connecting, only the keyboard backlight turns on and it restarts. That's all it does without an image, without fans, it just cycles through the reboot, turning only the keyboard backlight on and off.
    CPQK463 service tag​
  • frattainfo
    replied
    Great! Working Perfectly! Thank you
  • wilsonjfj
    replied
    Originally posted by qayyum786
    did you try to add service tag manually from bios setup ? if not than add your service tag in the bios setup problem should resolved
    if yes and problome remain same than
    Flash 8MB only from #131 and use your 16mb old
    Hello. I added the service tag yes. But the following is happening, when I restart or turn it off and on again, it doesn't show video. 2 orange and 7 white flashes (LCD display). But I already got a new screen and it's still the same thing. To show video again, just reset the bios or force it to turn on and off about 5 or 7 times until it shows video. But if you turn it off or restart it, it has no image and the LEDs blink like I said.
    Can you tell me what it could be?
    Thanks​
  • qayyum786
    replied
    Originally posted by wilsonjfj
    Hello. Can you help me? I have the Dell G3 3500 P89F002 notebook. It only shows video the first few times after resetting the bios. But it turns on and the video appears the same as the attached image, the fans are at maximum and when you click to enter the setup it restarts without video and the orange and 7 white LEDs (LCD) blink twice. I switched to the 8mb and 16mb bios from the last post by member "kostukas1985" and it worked but it keeps giving the Service Tag message.
    My Service Tag is 3JWR8G3
    Thanks.
    Flash 8MB only from #131​ and use your 16mb old
  • wilsonjfj
    replied
    Thanks.​
  • augustocs
    replied
    post #131... Working perfectly. After recording, it did not include the service tag. It required a restart once to allow this.
    Thank you, bios working, only one of several tested that worked.​
  • qayyum786
    replied
    Originally posted by kostukas1985
    He you go. 100 % working bios with service tag add and manufactoring mode disable.
    ❤️Extarnal link not allow❤️
  • kostukas1985
    replied
    Badcaps Electronics Repair Forum & Schematic Search
    Last edited by Vesko356; 02-25-2024, 04:08 AM. Reason: External url removed. File attached to post from external link.
  • DOCTORNOTEBOOKS
    replied
    gratitude worked, being able to add the normal tag thank you al l​
  • RJ_TECH
    replied
    Originally posted by DOCTORNOTEBOOKS
    sorry for the mistake,
    I can't add service tag
    It works but the cooler is accelerated and gives a tag error, I can't add it through the bios
    My Tag HJQ9M83
    thanks
    dell board 3500 pcb selek g3 mlk n18p 19795-1​
    Try a new bios from post #131
  • DOCTORNOTEBOOKS
    replied
    My Tag HJQ9M83
    thanks
  • BenCesur
    replied
    Thank you very much. It works smoothly. Perfect working.
  • Vesko356
    replied
    I NEED TO ADD SARVICE TAG
    What does it mean? What exactly is the issue? Where's your bios backup?
    Do NOT post in all caps!
    Read the rules before posting
    You MUST:
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
  • DOCTORNOTEBOOKS
    replied
    desculpe pela falha,
    não consigo adicionar service tag
    Funciona mas o cooler está acelerado e dá erro de tag, não consigo adicionar pela bios
    Minha Tag HJQ9M83
    obrigado
    placa dell 3500 pcb selek g3 mlk n18p 19795-1
  • mmccomputer
    replied
    Service Tag: CM191B3
    Try with new build
    Flash both
    Wait few minute after program file
    Must check with heatsink
    thanks my freind but is not working
  • qayyum786
    replied
    Try with new build
    Flash both
  • mmccomputer
    replied
    Originally posted by mmccomputer
    I am looking for a working bios for this model, I tried several without results (just the fans running at maximum and no display )​
    Dell G3 15 3500
    MB : G3 MLK N18P 19795-1 403YF$JA
    Service Tag : CM191B3
    this is my original bios
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • jhanra
    by jhanra
    in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
    11-02-2024, 04:19 AM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
  • mrrubik
    Dell Optiplex 7010 micro bad BIOS flash?
    by mrrubik
    Hi folks,
    I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
    After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
    Steps I took:
    1. Read BIOS with CH341a, verified hash twice
    2. Patched
    12-23-2024, 04:11 PM
