Lenovo Thinkpad T480 BIOS and EEPROM request
  • hoaca388
    replied
    Originally posted by PacoGT
    hello the laptop turn on and is on black screen, no video can you clearme , my bos thanks
    sn: pf-1gz3kw
    T480 Laptop (ThinkPad) - Type 20L6
  • PacoGT
    replied
    sn: pf-1gz3kw
  • Tix2
    replied
    Originally posted by Maxpower3
    not found computrace but autopilot yes
    try
    Worked.
    Thank you very much...
  • Maxpower3
    replied
    Originally posted by Tix2
    i have an Lenovo T480 with a company block or something like this.
    Whenever i tried to install Windows OS i have to connect to a company.
    Can someone help me to delete this?
    Thank you
    My laptop:
    Lenovo T480
    Type: 20L5-0007GE
    SN: PF-0YZ1R8
    try
  • Tix2
    replied
    Thank you
    My laptop:
    Lenovo T480
    Type: 20L5-0007GE
    SN: PF-0YZ1R8
  • kevinizm
    replied
    Originally posted by hoaca388
    PF-18HAF belong to Edge E531 (ThinkPad) - Type 6885
    Serial _PF18HCAF
    Sorry, you are correct, did you have a look at it? How messed up was it?
  • hoaca388
    replied
    Originally posted by kevinizm
    I mucked around with my bios a bit too much and now it doesn't power on, however still charges. I'm suspecting a fried motherboard and ordered a new motherboard just in case.
    I would be grateful for some help
    Type 20L6-S3H109 SN PF-18HAF
    Serial _PF18HCAF
  • kevinizm
    replied
  • Ivan Parra
    replied
    Just a question, by unlocking the advanced bios menu you can exceed the temperature limit of the GPU and CPU?
  • volinakis
    replied
    Originally posted by Ivan Parra
    Flawless and thank you very much :').what was the change?, if i may ask, im new in this literally since yesterday.
    I extracted bios region from update and replaced it in your backup and performed a clean_ME with intel FIT. You are welcome.
  • Ivan Parra
    replied
    Originally posted by volinakis
    try
  • volinakis
    replied
    Hi everyone, i just brick my t480 when i was updating the bios the laptop just shutdown, i supose the battery in bad condition.
    ​​I flashed a bios patched and only change mac, cause i read in a thread that just changing the mac had workdd, but didnt work for me. I want to know what else i need to do.
    I would vert greatful if you could help me.
    Lenovo et480 NM-B501
    SN: PF-1LQ0Q4
    try
  • volinakis
    replied
    Originally posted by monkeyclone
    Hey all,
    Having some trouble with patching my T480 bios so I can access the advanced menu. I dumped the bios and believed I patched it correctly, following a few guides. However when I reflash the laptop will let out a musical chime and not boot. I've tried a couple of times to fix the patched bios however I've hit a wall and have no idea what I'm doing wrong. Refreshing the original gets everything back to working order.
    Some searching has led me to believe it's the bios version that was on the laptop that could be causing issues. It's running 1.53 I believe and I saw people with 1.52 saying they had issues but I'm at a complete loss as to what I should do next.
    I've attached a copy of my working bios and a copy of the patched one. Any help would be massively appreciated and sorry for coming with what is probably a simple problem.
    Edit-
    apologies I missed the rule about where to post. my SN is PF-0YY9FP
    follow steps from autopatcher
  • Ivan Parra
    replied
    SN: PF-1LQ0Q4
    commented on 's reply
    Thread merged. Read the rules, please post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
  • monkeyclone
    replied
    Hey all,
    Edit-
  • qwerty4512
    replied
    Originally posted by Stefan Steff
    SORRY, allready post there
  • Stefan Steff
    replied
    Originally posted by qwerty4512
    I need your help, can anyone help me open the locked bios file?
    TYPE: T490
    CODE:NM-B901
    S/N:PF1VJMDX
    THANK YOU
    Here it's the T490 thread :
    https://www.badcaps.net/forum/troubl...t490-and-t490s
  • qwerty4512
    replied
    TYPE: T490
    CODE:NM-B901
    S/N:PF1VJMDX
    THANK YOU
    Last edited by SMDFlea; 01-07-2025, 03:02 PM. Reason: bios deleted, off topic........
  • _nedi_
    replied
    Originally posted by qayyum786
    Try
    Thanks man! It works perfectly!
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
    by to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
    I have opened the laptop and identified the main BIOS chip...
    10-24-2025, 01:35 AM
    Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
    09-06-2024, 03:21 PM
    09-06-2024, 02:34 PM
    09-06-2024, 02:28 PM
