Panasonic CF H2 MK1 Bios password help !
  • W140
    • Jan 2021
    • 13
    • t
    Hello to everyone.
    After setting the bios settings as default, bios set itself a password.
    please help remove the password. Thank you.
  • W140
    • Jan 2021
    • 13
    • t
    Re: Panasonic CF H2 MK1 Bios password help !
    Can some one please help unlock this panasonic CF-H2
    • W140
      • Jan 2021
      • 13
      • t
      up
      • W140
        • Jan 2021
        • 13
        • t
        So no body have it?
        • AAAC
          • Jan 2020
          • 458
          • Mexico
          I've checked your file two days ago trying to recover the actual password, but the password is hashed.
          So if you used a programmer to obtain the file you posted, then you can give a try to this file:
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            this is not full bios... better you read via spiprogrammer
            • W140
              • Jan 2021
              • 13
              • t
              sorry. it asks for password again.
              • W140
                • Jan 2021
                • 13
                • t
                added
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  added
                  try
                  • W140
                    • Jan 2021
                    • 13
                    • t
                    [QUOTE=rioreno;1015900]try[/QUOTE]
                    • W140
                      • Jan 2021
                      • 13
                      • t
                      try
                      enter password
                      • evserv
                        • Jun 2014
                        • 359
                        • Russia
                        Try
                        • W140
                          • Jan 2021
                          • 13
                          • t
                          Originally posted by evserv
                          Try
                          Thank you
                          is working
                          • Rizaraj
                            • Apr 2022
                            • Belgium
                            Hello ,
                            I am new here . I bought a 2nd hand CF-H2 windows was in French so i thought lets just uodate it but i made the mistake of updatingnit to 32 bit .
                            Ok no problem kets just format it and install a fresh copy 64 bit but guess wat cant get in biis has a password .
                            I was wandering how does this work apparently it can be bypassed .
                            Can u plz help ?
                            • punka
                              • Jul 2023
                              • 3
                              • France
                              Try
                              ho thank you very much :novice: my first day on the forum and I have already found a solution to a panasonic CF-H2 the bios is displayed without password now but I have the message "me is in recovery state" I did not have time to check what I could do about it, well done
                              • punka
                                • Jul 2023
                                • 3
                                • France
                                Panasonic CF-H2 help would be appreciated
                                Hello everyone, I managed to reprogram my BIOS using the file provided by [https://www.badcaps.net/forum/showpo...&postcount=12]. I want to express my gratitude to them. It was done on a Panasonic CF-H2 "CF-H2AU24EF3" which I believe is an MK1 model. However, I'm now facing a new issue. Whenever I start up the PC, I encounter the infamous 'me is in recovery state' error. If anyone has a moment to advise me, I would appreciate it as dealing with BIOS is not my expertise...for now Thank you in advance.
                                • STKR123
                                  • Jun 2023
                                  • 12
                                  • Country
                                  Hi!
                                  Would this solution be based on using a SPI Reprogrammer only?
                                  Or is there a chance to flash the BIOS via the Windows award tool and/or using a USB Drive in DOS Mode?
                                  • outsider
                                    Panasonic FZ-G1 MK5 - BIOS password returning
                                    by outsider
                                    Hello
                                    I removed the BIOS password thanks to the help of one of the friends of this forum.
                                    https://www.badcaps.net/forum/troubl...61#post3637661
                                    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                    06-17-2025, 12:51 AM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • longmt1990
                                    Panasonic Cf-w5 bios password remove
                                    by longmt1990
                                    Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                    I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                    Please help me remove bios password.
                                    Thank you so much
                                    07-06-2025, 10:50 PM
                                  • Nopslide
                                    by Nopslide
                                    04-01-2024, 04:27 PM
                                  • AquaMan Ua
                                    by AquaMan Ua
                                    05-17-2025, 09:40 AM
