P52 Bios 20m9 Need
  • black0hackers
    • Jul 2020
    • 365
    P52 Bios 20m9 Need
    Some one have P52 Type 20M9-000LUS can share me please!
    My org bios turn on but not coming display!
  • ScorpioMan86
    • Dec 2016
    • 94
    • South Africa
    Re: P52 Bios Need
    What is your board model number ?
    • peste
      • Dec 2016
      • 12742
      • ROMANIA
      Re: P52 Bios Need
      try..
      • black0hackers
        • Jul 2020
        • 365
        Re: P52 Bios Need
        Originally posted by peste
        try..
        thank you for your help!
        it power on and still no display.
        sound beep playing
        i used Lenovo PC Diagnostic check and get info like picture attach
        • siwykk
          • May 2020
          • 54
          • N/A
          Re: P52 Bios Need
          sound beep playing
          Try this one.
          • black0hackers
            • Jul 2020
            • 365
            Re: P52 Bios Need
            Originally posted by siwykk
            Try this one.
            Thank you so much!
            • Clarify4082
              • Oct 2022
              • 61
              Lenovo P52 BIOS
              I need P52 BIOS please.
              Model: 20M9
              Serial: PF-1FR56Y
              Bootloop with the orignial...
              Backup bios attached
              • hoaca388
                Badcaps
                • Jan 2022
                • 11700
                Re: Lenovo P52 BIOS
                Model: 20M9
                Serial: PF-1FR56Y
                P52 (Type 20M9, 20MA) Laptop (ThinkPad) - Type 20M9
                • Clarify4082
                  • Oct 2022
                  • 61
                  Re: P52 Bios 20m9 Need
                  Not working, power LED lights up, power button blink 3 times. No fans, no beeps, nothing
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11700
                    Find hardware causes.
                    • Clarify4082
                      • Oct 2022
                      • 61
                      Tried to change RAM etc. nothing worked. With the old bios the fans are spinning and I get beep codes if RAM is missing. So I think there is no hardware issue!?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11700
                        Sorry to tell you that this problem is not caused by the bios.
                        • Clarify4082
                          • Oct 2022
                          • 61
                          Re: Lenovo P52 not powering up
                          I´ve flashed again the version attached. I´ve got it from this forum, but don´t remember the exact post, I´ll try to figure it out.
                          With this BIOS, the Laptop is starting. I get no HDMI output, but I get the error code 0288 for Display Error, wich is fine, because there is no internal display attached.
                          Also I get 4 short beeps.
                          The system starts directly when I plug the charger. No blinking on power led. Power off and power on again works with the power button.
                          Fans are spinning and the system stays on.
                          I think the hardware is fine, otherwise the laptop wouldn´t start?
                          I´ve checked the bios with ME Analyzer, it says:
                          Note: This CSE ME firmware was not found at the database, please report it! (See attachements)
                          Any ideas on this?
                          • Clarify4082
                            • Oct 2022
                            • 61
                            Hello again ,
                            checked everything hardware related, I think it´s not a hardware issue. (See: https://www.badcaps.net/forum/showth...&highlight=P52)
                            I´ve tried to extract a fresh bios from the original Lenovo file to flash this, but Innoextractor don´t give me a .exe or .cap file.
                            Can you extract a fresh bios from the original installer (attached)?
                            thanks!
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11700
                              Hello again ,
                              thanks!
                              Here
                              • Clarify4082
                                • Oct 2022
                                • 61
                                Thank you!!
                                Finally the spare LCD-Screen arrived and I got the laptop working with the bios attached (working_20230919).
                                There is one thing that needs to be fixed.
                                With the running bios (working_20231909), everything works fine but it takes 30 seconds to get to the Lenovo boot image.
                                So I think this is because of a bad/missing/wrong ME.
                                But if I patch a bios you provided with a new/cleaned ME the Laptop don´t power on.
                                If I try to clean the ME on (working_20230919) I get an Error in the intel flash image tool (see attachments).
                                Can you please have a look again?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11700
                                  Thank you!!
                                  File's corrupted
                                  • Clarify4082
                                    • Oct 2022
                                    • 61
                                    Sorry, next try.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11700
                                      Sorry, next try.
                                      Here you are
                                      • Clarify4082
                                        • Oct 2022
                                        • 61
                                        Thank you very much!
                                        Everything works now
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
