please patch this ThinkPad S1 Yoga 12
  • sonsy
    • Mar 2017
    • 71
    • Serbia
    Re: please patch this ThinkPad S1 Yoga 12
    Originally posted by Maxpower3
    Edit: SOLUTION FIND
    DON'T USE FILE WITH PDF
    JUST REPLACE 0x200 to 022F on your original EC Dump
    no lost UUID ,serial and others numbers
    can you be more precise please? Am I reading only the 4MB chip, and am I replacing only the values I see in the image with "00"? Thanks!
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      need read kbc 9022 and change values (JUST REPLACE 0x200 to 022F on your original EC Dump)
      • adil12
        • Sep 2020
        • 12
        lenovo yoga 12 bios locked help please
        hello,
        can you please help unlock my yoga 12 bios dump attached.
        Thank you
        • spuree11
          • Jun 2018
          • Serbia
          I have a ZIPS3 LA A342P For Lenovo ThinkPad Yoga 12 Laptop with a locked bios, can somebody patch it?
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1356
            • France
            read EC ,solution here
            https://www.badcaps.net/forum/showpo...4&postcount=19
            • SiO2
              • Apr 2022
              • 24
              First of all, thank you so much for figuring this out and sharing the solution!
              I used your technique to read and clear the UEFI password of my Yoga 12.
              Now for the remaining problem: Even though I can now enter the UEFI by just pressing enter (empty password), I cannot change any settings. I guess this is because the "lock UEFI BIOS settings" option is set to enable. Probably this prevents me from making any changes.
              Any thought on how this can be resolved?
              EDIT: Nevermind. I repeated all steps from scratch and now it works
              • Alassane
                • Oct 2018
                • 65
                • MALI
                #27
                Re: Bios yoga12
                Originally posted by rachidell
                Sorry for the delay
                Thanks in advance
                thanks very much
                • TJJones94
                  • Sep 2021
                  • 7
                  • Darwen
                  #28
                  where can I get this chip reprogrammer from?
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1356
                    • France
                    #29
                    News
                    Patch possible on yoga 12
                    Pach by bios, no need to reprogram EC (Kb9022Q)
                    - Just read the two bios files (8+4MB)
                    and join them with utility provided.
                    Click image for larger version  Name:	Sans titre.jpg Views:	0 Size:	143.6 KB ID:	3227238
                    Use Uefi Tools to modify your BIOS
                    Extract as is LenovoPasswordCP E4F272DA-237F-454C-8868-FCF096CF1C6C
                    Search AA382865-12B0-44E5-A731-6DEF4DF34CE7 LenovoPromptService
                    Replace as is LenovoPromptService by LenovoPasswordCP
                    LenovoPasswordCP must appear twice after
                    Split your file, select 8 for first file
                    Cleaning can help but not necessary
                    Password CP and Prompt may appear several times in relation to the bios templates, so all of them will need to be replaced
                    The patch allows you to access setup
                    - Load by default for the first time and restart
                    - Enter setup and go security
                    - type a blank password twice and save.
                    - Turn off, restore your original bios.
                    If you don't restore, the password will never be asked again!!
                    Tested here : https://youtu.be/f43JuDzA3yU
                    Booting may take time with different melodies, be patient!!
                    This patch also works on other models
                    https://www.badcaps.net/forum/troubl...10#post1873410
                    I'll leave you tested,
                    No Prompt, No Password
                    For clear EC KB9022Q as previously cited
                    Just replace 0x200 to 022F on your original EC Dump
                    Click image for larger version  Name:	PWD CLEAR.jpg Views:	0 Size:	47.1 KB ID:	3227237
                    Can someone help me create a patcher with python
                    because the autopatcher does not extract, just replaces.
                    I don't understand anything about python
                    • Davidscheiber28
                      • Jul 2018
                      • United states
                      #30
                      STUFF
                      I tried this but for some reason I cannot get the laptop to boot with the modified image
                      What am I doing wrong, Is there a trick to getting it to boot with the modified BIOS?
                      I tried also the auto patcher linked here https://www.badcaps.net/forum/troubl...age169?t=87588
                      but could not get it to boot.
                      I attached the original BIOS file reads, read and flashed with a CH341A.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1356
                        • France
                        #31
                        try only 64,32 it's same
                        • Davidscheiber28
                          • Jul 2018
                          • United states
                          #32
                          I flashed the 8 MB W25Q64FV chip with the file "64 try test.bin" but still was not able to get a boot after trying for a while. The CPU fan spins for 3-5 seconds before stopping, CPU gets warm no video on display.
                          I also tried with and without the CMOS battery and also pressing the button on the motherboard.
                          I have only the display, charger and power button&sata board connected not sure if that matters but it would boot previously like this.
                          I had noticed the 4 MB part of the image was the same for the stock and modified so I only verified the dump matches before reinstalling. (I also verified the 8 MB chip after flashing)
                          Maybe I am doing something wrong in programming? Not sure.
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1356
                            • France
                            #33
                            If you put the original back, does it work again? So the programming is good​
                            • Davidscheiber28
                              • Jul 2018
                              • United states
                              #34
                              This is very strange, I programmed the original BIOS back to the 8M chip and the board still does not boot, I even tried swapping the flash chips off a similar dead board (shorted PCH) and still got no boot.
                              I verified with an older board the LCD is still working also.
                              I have been comparing this board to the dead one to see if I knocked off a component but I don't see any knocked off. There are some resistors in different positions but I believe those are the straps for the ram as the dead board only had 4GB of ram if I recall and the locked one has 8GB.
                              Any idea what might have happened?
                              Maybe I somehow killed the SIO? I'm assuming the power rails are all present since the CPU has power right? I would think that would be last in the sequence.
                              I also wonder about the ram solder balls but I would think I would get a beep code if one of the ram chips became disconnected.
                              I must have screwed something up but I have know idea what I did .
                              • gereonb
                                Rad Caps
                                • Jan 2024
                                Was successful using merge method original dump 8MB+4MB=12MB.bin, running it through lenovo-autopatcher, split it again 8MB+4MB. Burn the modified 8MB (4MB will be same as original) to boot & reset TPM, and then reflash the original 8MB dump.
                                • benjas11
                                  • Jul 2024
                                  • 15
                                  • Mexico
                                  #36
                                  Hello eveyone, I would like to know if someone here still have the lenovo yoga 12 working. I would like to ask for some features about bios version and chipset version because i am facing a problem with a lenovo yoga 12, it only shows video by a external monitor but no video on display. I have a new lcd flex, new screen, no backlight problem. Everythings looks ok but somehow doesnt detect the lcd.
                                  • peste
                                    • 13756
                                    • ROMANIA
                                    #37
                                    if it displays on the external monitor, it's not a bios problem... check the LVDS cable, display, connectors, video chipset... move the discussion to the main forum...
                                    • benjas11
                                      • Jul 2024
                                      • 15
                                      • Mexico
                                      #38
                                      The issue is that I got a display on the LCD with an Ubuntu Live USB, but only until the system finished booting. All previous system messages were ignored by the LCD (but appeared on the external monitor). So I decided to reflash the BIOS. After that, I only had the external monitor working. Things got weird from there because even after reflashing the original BIOS, I couldn't get the Live USB video output back.​
                                      • gereonb
                                        Rad Caps
                                        • Jan 2024
                                        The issue is that I got a display on the LCD with an Ubuntu Live USB.
                                        You were asked to start a new thread as this issue is not related to the Original Posters issue.
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                          Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 04:10 AM
                                        • Loki_Fido
                                          Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
                                          by Loki_Fido
                                          Hi everyone, hope everyone's having a great day.
                                          I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
                                          I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
                                          So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
                                          Does this mean the BIOS is fine? making it a hardware issue?
                                          I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
                                          03-14-2025, 07:42 PM
                                        • Maxpower3
                                          Brand name and Model Type for Lenovo error 2202 product name is invalid
                                          by Maxpower3
                                          Info for error 2202 LenovoThinkPad models and type
                                          Extract from ThinkPad Maintenance Utilities Configuration File
                                          plnsrv.ini Version 1.01
                                          Some information that may be useful
                                          There must also be missing models, add them to the list if you know of any.
                                          Code:
                                          brand name
                                          20B1=ThinkPad Edge E445
                                          20B2=ThinkPad Edge E545
                                          20BC=ThinkPad Edge E145
                                          20BM=ThinkPad X140e
                                          20BL=ThinkPad X140e
                                          20A3=ThinkPad X230s
                                          20AH=ThinkPad X230s
                                          20AK=ThinkPad X240s
                                          20AJ=ThinkPad X240s
                                          02-21-2024, 10:27 AM
