NEED REPAIR BIOS Asus X550VX Rev 2.0
  • enversefa
    • Oct 2016
    • 25
    • istanbul
    Asus X550VX Rev 2.0
  • marcin02152
    • Oct 2014
    • 134
    • Polska
    Re: Asus X550VX Rev 2.0 work
    • bilen
      • Aug 2014
      • 637
      • istanbul
      X550VX rev 2.0 need 950m bios dump
      Hi . my bios nvidia gpu showing error.
      can anyone fix this. old dump :
      • peste
        • Dec 2016
        • 13747
        • ROMANIA
        Re: X550VX rev 2.0 need 950m bios dump
        try
        • bilen
          • Aug 2014
          • 637
          • istanbul
          Originally posted by peste
          try
          the fan is constantly running fast and nvidia no longer exists
          • peste
            • Dec 2016
            • 13747
            • ROMANIA
            try..extras asus site..
            • bilen
              • Aug 2014
              • 637
              • istanbul
              nothing has changed
              thank you for your help.
              nvidia gpu faulty
              I disabled it improved
              • ddhlawi
                • Feb 2017
                • 169
                • algerian
                try this brother
                its new region
                • bilen
                  • Aug 2014
                  • 637
                  • istanbul
                  Originally posted by ddhlawi
                  try this brother
                  its new region
                  nvidia gpu faulty
                  • baothmen
                    • May 2019
                    • 15
                    • tunisia
                    PLEASE I NEED REPAIR MY BIOS Asus X550VX Rev 2.0
                    • peste
                      • Dec 2016
                      • 13747
                      • ROMANIA
                      Re: NEED REPAIR BIOS Asus X550VX Rev 2.0
                      try..
                      • kalilinux25
                        • Mar 2018
                        • 2093
                        • ZAMBOANGA SIBUGAY
                        try..
                        you have ec?
                        • peste
                          • Dec 2016
                          • 13747
                          • ROMANIA
                          Originally posted by kalilinux25
                          you have ec?
                          try..
                          • NoteX-Bilişim
                            • Dec 2022
                            • 6
                            • Türkiye
                            try..
                            not working..
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • pirati
                              by pirati
                              10-27-2025, 04:20 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
