Odis Winbook 13
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Odis Winbook 13
    odys winbook 13 bios dump
    motherboard EM_A6211_178B_V1.0
  • peste
    • 12569
    • ROMANIA
    Re: Odis Winbook 13
    post the full name and model, and the original bios.
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      Re: Odis Winbook 13
      Unfortunately I only have this data, it is a Chinese laptop marketed in Germany, it has a dedicated memory for the ITE and the main bios.
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • grimacelord
        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
        by grimacelord
        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
        Motherboard model number: DA0PAMB46A1 REV: A
        Secondary motherboard model number: 0PAB
        SKU: 685K4UA
        Serial number is: 5CD3223BJP
        Recently reflashed this laptop with latest BIOS and once...
        05-07-2024, 08:06 AM
      • DynaxSC
        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
        by DynaxSC
        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
        11-06-2022, 05:22 PM
      • TacticalFahrrad
        [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
        by TacticalFahrrad
        I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
        06-30-2025, 04:09 AM
