gs44d/gs54d nm-c711 rev1.0 HELLPPPP!
https://www.badcaps.net/donate -
PLEASE fix the bios image, i do not get video.
lenovo v15-iil
motherboard gs44d/gs54d nm-c711 rev1.0Attached Filesif you find these attachements useful please consider making a small donation to the site
sorry
lenovo v15-iil
serial PF29D7CP
factory id: jvhfc1
moodel name 82c5Comment
HERE IT IS
FACTORY FILE WITH DMI INJECTED
ENJOYAttached Filesif you find these attachements useful please consider making a small donation to the site
#43 Is Good , thanks .
At what address is the DMI data (sn, win key, etc.)? I want to copy from a damaged dump to a new oneComment
Every donation made will go towards server fees and maintenance costs.Comment
Please help me brother, my laptop no display issue
model: lenovo s145-15iil
serial number: PF234948
board part number: GS44D/GS54D NM-C711 REV 1.0Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks brother, but my laptop still now no display issue . cpu hit and fan open all is ok but no displayComment
nm-c711
only onboard ram working, cannot add or upgrade ramAttached Filesif you find these attachements useful please consider making a small donation to the site
Type the laptop serial number, full name and model
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
by BlackHhello friends..
DC Jack is ok.. 20V entering the first MOSFET,, but nothing out..
using my power jack to inject 20V after the first MOSFET, nothing out.
but after inject 20V after the second FOSFET, the board worked,,
when i remove the first MOSFET,, and inject 20V at the input of second MOSFET, the board worked,,
try to change the first MOSFET,, but nothing changed.
so i try to jumber the first MOSFET,, all things worked .. but the board can't charge the battery.
i test the battery,, and its working very good..
any suggestions?... -
Hello I Need to Clear this Bios Password
LENOVO V15 IIL GS44D GS54D NM-C711
I Write another to password cleared But Hdd Not detected
So Pls Need to Clear this bios Password...-
Channel: BIOS Requests ONLY!
by dr.thodtFor the second time this week I received a Lenovo laptop with onboard ram and one sodimm slot. Both laptops run stable from their onboard 4GB RAM, but turn out to be very unstable when there's a sodimm inserted in the slot.
Both times it was a GS44D/GS54D NM-C711 rev 1.0 board.
Both times there were no loose pins on the slot and it did not matter what sodimm I put in. It just artefacts and crashes randomly when there's extra ram.
What I did notice is that almost all coils have very dirty phases one the mosfet side when checked with an oscilloscope. Not something I see very often....06-07-2024, 09:16 AM -
by DrFalkenHello guys,
Lenovo V15-IIL M/B GS44D/GS54D NM-C71 Rev 1.0
Customer say that this laptop died righe after connecting an cheap aftermarket PSU.
Some readings:
- VIN = 20V
- PQ100 pin1-3 = 0
- PQ100 pin4 = 0
- PQ100 pin5 = 20V
- V9B+ [PR100 pin4] = 0
- +3VALW [RI4509 pin2] = 0
- +5VALW [UI4302 pin5] = 0
- +3VALW_PCH [DC701 pin2] = 0
- +1.8VALW [RX4601 pin1] = 0
- +VCCIN_AUX [PL9801 pin2] = 0
- ACDRV [PR105 pin2] = 0
- REGN [PC118 pin1] = 6,65V -
by ArminioHi all, I'm new to the forum and need some help....
I have a notebook with a gs44d/gs54d nm-c711 motherboard which, after a few days of turning on and off by itself, never turned on again. there seems to be no power.
thank you - Loading...
