840 G1 Bios problem- can't enable wifi
  • tinto
    • Jul 2017
    • 74
    • serbia
    hello
    can anyone help me
    i think the problem is BIOS, the laptop is working normally, the bios is unlocked
    but I can't turn on WIFI....I tried everything..
    can anyone REPAIR my original BIOS
    this is my Original dump
    thanks
  • peste
    • 13924
    • ROMANIA
    Re: 840 G1 Bios problem- can't enable wifi
    Originally posted by tinto
    hello
    can anyone help me
    thanks
    try..
    • tinto
      • Jul 2017
      • 74
      • serbia
      peste
      your dump is not good
      can't show picture, caps lock+ num lock blinking.....bios is bad
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        try and report
        • tinto
          • Jul 2017
          • 74
          • serbia
          Claudiomfa
          Machine Is Not In Committed State....your dump work.... Thanks
          but i found problem on motherboard...some water made a short circuit...
          • cr4zychriss
            by cr4zychriss
            • Rebrand: PC Specialist
            11-14-2025, 04:04 PM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
          • traxformania
            TONGFANG "GM7TG7P" Bios Password Problem?
            by traxformania
            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
            I'm trying to reset my bios without success.
            I tried :
            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
            11-15-2023, 07:32 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
