MAC BIOS for cleaning.
  • vikivng
    • Feb 2019
    • 228
    Hi again guys,
    can someone check this file pls and help me remove password.?
    Is this file too small.? It has been verified..pls check.
  • Ghamidi
    • Mar 2020
    • 306
    • France
    Re: MAC BIOS for cleaning.
    Originally posted by vikivng
    hi again guys,
    try...
    • vikivng
      • Feb 2019
      • 228
      Thanks alot..works.
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
        by m1ch43lzm
        Hi everyone
        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
        There's also an extra OTP Secu.R...
        09-06-2025, 05:47 PM
      • survivalbloke
        If I flash this bios file, will it just work, or does it need the ME cleaning?
        by survivalbloke
        I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
        ENVY X360
        15-ew0013dx
        SN: CND2261KS3
        Prod: 698V0UA
        Board: LA-M021P Rev 1A
        Chip# Winbond 25R128JVSN​
        Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...
        10-09-2024, 08:40 AM
      • Forest79
        by Forest79
        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
        07-23-2023, 07:39 AM
