BIOS dump for Asus UX501J (501JW-DH71T)
  • mad_dj
    • Jul 2018
    Hi
    What about BIOS dump for Asus UX501J (501JW-DH71T)
    May be have somebody?
  • peste
    • 12729
    • ROMANIA
    Re: BIOS dump for Asus UX501J (501JW-DH71T)
    Originally posted by mad_dj
    Hi
    post the original laptop bios
    • mad_dj
      • Jul 2018
      Have already found.
      Thank you
        • 20781
        Have already found.
        Thank you
        Please post the bios,it may help someone.
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Anchar777
          ASUS P1412CE need BIOS DUMP
          by Anchar777
          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
          06-26-2025, 03:39 AM
