Bios crashed in E490 update bios
  • myhp1998
    • Mar 2022
    • Malaysia
    Re: Bios crashed in E490 update bios
    I have a same E490 Lenovo laptop (FE490 NM-B911 rev 1.0) that cannot turn ON (blank screen, Keyboard CapsLock button light ON, Fan spinning and can feel warm from processor). Already took out battery and BIOS battery (short n put back) but still same. Any clue on how to troubleshoot and if this could be related to BIOS?
    • Blackam8899
      • Sep 2020
      • 45
      • Rosario
      I'm having the same problem and I don't have a Vcore signal either, I tried several bios but it still has the same problem, I'm suspecting the CPU controller that doesn't pull the pwm to the integrated vcore, but it could also be a bios problem, I'm in an alley No Exit.
      Does anyone have a BIOS that works correctly for E490?
      • Blackam8899
        • Sep 2020
        • 45
        • Rosario
        e490 nm b 911 rev 2.0 bios
        Hello, my team model E490 20N9 lenovo with mother: e490 nm b 911 rev 2.0 bios.
        IT TURNS ON THE POWER LIGHT AND THE CAPS KEY LIGHT BUT IT DOESN'T START, IT ONLY POLARIZES THE SCREEN IN BLACK, THERE IS NO vCORE SIGNAL. APPARENTLY IT IS A BIOS PROBLEM CAN SOMEONE CLEAN MY BIOS AND LEND ME A WORKING BIOS?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12278
          Re: e490 nm b 911 rev 2.0 bios
          Just calling is useless if you don't upload here the existing bios file on your computer.
          • Blackam8899
            • Sep 2020
            • 45
            • Rosario
            Excuse me, I'll upload the file if someone can clean my bios or if they have a functional one, thanks in advance!
            • hoaca388
              Badcaps
              • Jan 2022
              • 12278
              #26
              E490 (Type 20N8, 20N9) Laptop (ThinkPad)
              • Blackam8899
                • Sep 2020
                • 45
                • Rosario
                #27
                Thanks, I'll try it out and I'll tell you how it went later!
                • Blackam8899
                  • Sep 2020
                  • 45
                  • Rosario
                  #28
                  It did not work, it continues in the same sequence, sometimes Vcore is activated but another source of the cpu is deactivated, it polarizes the screen but does not give an image.
                  Can someone clean this bios?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12278
                    #29
                    Here
                    • Blackam8899
                      • Sep 2020
                      • 45
                      • Rosario
                      #30
                      Here
                      We tried it but it didn't work, the equipment turns on but doesn't give an image and Vcore doesn't work, there are no signals of the pulses in the IC PU401 pwm1. someone has something similar happen?
                      • Blackam8899
                        • Sep 2020
                        • 45
                        • Rosario
                        #31
                        Hello I need EC DUMP for FE490 NM-B911 REV: 2.0 someone who can help?
                        I read its content with the SVOD and it is blank, the equipment turns on but its secondary sources such as Vcore do not work, it seems that the kbc is UNPROGRAMMED, someone to help? FE490 NM-B911 REV:2.0
                        • dgs3342
                          • May 2017
                          • 36
                          • Italia
                          #32
                          Originally posted by santoslao
                          I thank the forum but I managed to solve it...
                          How did you resolved it?
                          • DaFluepp
                            • Oct 2019
                            • 57
                            • Deutschland
                            #33
                            Hi, can anybody repair my Bios-Dump for Thinkpad E490 ( 20N8-CTO1WW ).
                            thx Flueppi
                            • hardware1
                              • Sep 2021
                              • 2946
                              • N/A
                              #34
                              thx Flueppi
                              Write your device serial number.
                              What's your device problem?
                              all donations are welcome,
                              • DaFluepp
                                • Oct 2019
                                • 57
                                • Deutschland
                                #35
                                Serial : PF-1LRTWW , after Biosupdate only Blacksreen.
                                • hardware1
                                  • Sep 2021
                                  • 2946
                                  • N/A
                                  #36
                                  Here's your new file, try it and let me know.
                                  • DaFluepp
                                    • Oct 2019
                                    • 57
                                    • Deutschland
                                    #37
                                    thx very much, now system is beeping and blackscreen ( Code0001 )
                                    • hardware1
                                      • Sep 2021
                                      • 2946
                                      • N/A
                                      #38
                                      What does you mean by code0001? Is it shown on the screen?
                                      • DaFluepp
                                        • Oct 2019
                                        • 57
                                        • Deutschland
                                        #39
                                        no, it is the beeping code from the app
                                        • hardware1
                                          • Sep 2021
                                          • 2946
                                          • N/A
                                          #40
                                          Maybe it's a hardware issue. create a new thread there.
                                          https://www.badcaps.net/forum/forumdisplay.php?f=23
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
                                          • al3m0di
                                            Update bios EFCN58WW to EFCN59WW
                                            by al3m0di
                                            Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                                            I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                                            The BIOS version is EFCN58WW.
                                            When I turn on the device, it displays the message:
                                            "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                                            The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                                            I've tried
                                            07-29-2024, 10:32 AM
                                          • 0xx
                                            2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                            by 0xx
                                            Hi folks,
                                            My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                            What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                            I assumed that Windows Update was interrupted due to closing...
                                            09-14-2025, 03:46 PM
                                          • trix11
                                            Dell Precision T1650 MT Workstation bricked after BIOS update
                                            by trix11
                                            I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                            - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                            - Dell Precision T1650 mid tower Workstation
                                            - Xeon E3-1225 V2
                                            - 32Gb PC3-12800E RAM
                                            - 4Tb SATA HDD
                                            - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                            I see now that others have experienced like issues e.g.:
                                            - https://www.dell.com/community/Prec...
                                            10-24-2022, 10:35 PM
