17r 5753 modded bios request
  • DiegoDong
    • Oct 2020
    • 5
    Hello everyone. So ATI card failed on it. Looking to disable it. I have attached my bios dump, so if anyone could mod my bios so I could disable it. I would very much appreciate it. Thanks
    • 20795
    Re: 17r 5753 modded bios request
    Disabling the GPU should be done in hardware.Not all boards can be disabled.
    • DiegoDong
      • Oct 2020
      • 5
      Im completely aware of that, but sometimes theres an option in bios to disable switchable graphics, so it wouldn load the driver and freeze. And sometimes that option is not there. But thanks for reply. What about disabling the power supply on the board for GPU? Would it still boot?
      • Bonzas
        • 471
        • Indonesia
        where you got stuck ?
        on OS or before loading OS ?
        if you have problem with the driver, try to install legacy mode, not UEFI.
        • DiegoDong
          • Oct 2020
          • 5
          In the OS, boots up fine, well, fineish, takes bit extra to post, but if driver is present, as soon as it gets initiated I get a black screen. No driver, no problem. So in my mind, no gpu=no driver to load=no problem. I will try legacy mode on monday. Thanks again
          • DiegoDong
            • Oct 2020
            • 5
            Well. Putting it in legacy mode gives me a black screen, and requires removal of bios IC and reflashing. Any more ideas?
            • Mr.Ultimate
              Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
              by Mr.Ultimate
              Hi everyone, hope to get someone to help and modify bios rom for me.
              I need to disable dedicated nvidia graphics chip permanently.
              GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
              Ideally if it was disabled from bios at preboot.
              I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
              08-06-2024, 05:15 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
