Macbook Pro A1706 EMC 3163 820-00923-A-password
  • ibrahim03
    • Oct 2015
    • 143
    • egypt
    i need remove password
    thanks advanced
  • piszpunta
    • Jan 2019
    • 249
    • poland
    Re: Macbook Pro A1706 EMC 3163 820-00923-A-password
    try
    • capon5153
      Macbook A1706 works perfectly but no data on USB C
      by capon5153
      hello,
      so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
      i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
      06-22-2025, 09:42 AM
    • B2L_Repairs
      Macbook A1706 touchpad and keyboard not working. Please help
      by B2L_Repairs
      Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
      10-09-2023, 04:56 AM
    • obelix24
      A1706 - Macbook pro - one USB-C port only 20V 0A
      by obelix24
      I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
      I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
      There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
      There were some broken pads under CD3215 but i've recreated them.
      What should be...
      05-22-2024, 08:04 AM
    • zakeric
      Need macbook A1706 3163 bios dump
      by zakeric
      dump original...
      09-13-2021, 04:26 AM
    • johnbeton
      Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
      by johnbeton
      I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
      Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
      This is what I measure so far:
      Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
      PPBUS_G3H = 0,79v
      PPBUS_HS_CPU = 0,79v
      PPBUS_HS_OTH5V = 0,79v
      PPBUS_HS_OTH3V3...
      05-21-2024, 02:06 PM
