can someone please help me i need a working dump,motherboard code NIKE15-R-BBY REV 1.0-1(BA41-02050AN Y).
samsung np700z5c-s03it bios
Tags: None
Re: samsung np700z5c-s03it bios
Thanks anyway problem soved.here is a working dumpAttached FilesLast edited by bachir2004; 10-05-2020, 04:30 PM.Comment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by zPwN!Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
System SKU NE14I310
BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
Motherboard XU133T rev 1.3
Serial Number IPNBI3X240SM2A01095
Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
RAM 8.00 GB
NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...-
Channel: BIOS Requests ONLY!
by SparklingxHi,
So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
now all... - Loading...
