hp elitebook 850 g5 bios password
  • neskajy-91
    • Dec 2021
    • Russia
    #61
    Re: hp elitebook 850 g5 bios password
    Hi everybody? i need help, i can't remove pass, like many people of here... Please help me
    • mnciks11
      • Aug 2019
      • 346
      • south Africa
      #62
      Hello guys, im facing a problem here, same machine came to me dead, managed to fix it by changing 2 components supplying the cpu volts, now the machine is turning on but looping after a logo, shows an hp logo, then loop, repeat the same thing over and over again.
      My backup file is below, tried cleaning the ME Region but no changes, maybe someone can assist me
      • hoaca388
        Badcaps
        • Jan 2022
        • 12426
        #63
        Post more main bios file.
        ​https://www.badcaps.net/donate
        • hoaca388
          Badcaps
          • Jan 2022
          • 12426
          #64
          HP EliteBook 850 G5 Notebook PC
          • mnciks11
            • Aug 2019
            • 346
            • south Africa
            #65
            Im getting the same results, at first it said something about mismatch data on the Ec, and then goes back to looping.
            i believe the machine is gonna be okay, let me extract the other bios and post it here
            • mnciks11
              • Aug 2019
              • 346
              • south Africa
              #66
              Here we go, the other bios is attached below
              Thanks in advance
              • strujaze
                • May 2015
                • 11
                • Bosna i Hercegovina
                #67
                Hi. I need delete the password bios of a hp elitebook 850 g5
                prod id 2fh33av
                sn 5cg8512zsc
                thanks in advance
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12426
                  #68
                  prod id 2fh33av
                  sn 5cg8512zsc
                  thanks in advance
                  RC Unlocker for moj u366 25q128jv
                  • strujaze
                    • May 2015
                    • 11
                    #69
                    i have tried rc unlocker and hp unlocker,no display after programing
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12426
                      #70
                      Reprogram carefully
                      • strujaze
                        • May 2015
                        • 11
                        #71
                        Reprogram carefully
                        thank you for quick replay,but i have tried couple of times to reprogram,5-6 times,same no display,old locked dump working
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12426
                          #72
                          sssss
                          • strujaze
                            • May 2015
                            • 11
                            #73
                            sssss
                            no display,caps lock blink 3 times,fan run at full speed
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12426
                              #74
                              OMG, sorry, I posted the wrong file
                              • klynstronic
                                • Jun 2022
                                • 45
                                • españa
                                #75
                                Hi.
                                Can anyone clear the password from this for me please?.
                                Computro-6050A2945601-MB-a01(A1). Elitebook 850 G5.
                                  • 22206
                                  Originally posted by klynstronic
                                  Hi.
                                  Serial number ??? .Have you tried RCUnlocker on the 16MB chip ???
                                  • klynstronic
                                    • Jun 2022
                                    • 45
                                    • españa
                                    #77
                                    RCUnlocker Ok. Thanks.
                                    • alltalk
                                      • Sep 2015
                                      • 28
                                      • england
                                      #78
                                      Re: RCUnlocker
                                      hi
                                      tried rcunlocker on the 16mb chip on 850 g5
                                      generated an unlocked file but bios is still locked
                                      any help greatly appreciated
                                      both files attached
                                      prodid 2FH35AV
                                      sn 5CG8522C55
                                      • rex98
                                        • Feb 2023
                                        • 1297
                                        • Mandaue CEBU, Philippines
                                        #79
                                        Re: RCUnlocker
                                        Originally posted by alltalk
                                        hi
                                        both files attached
                                        prodid 2FH35AV
                                        sn 5CG8522C55
                                        Try flash that both main and ec then give feedback.
                                        make sure you back-up the original main dump before flashing.
                                        • alltalk
                                          • Sep 2015
                                          • 28
                                          • england
                                          #80
                                          the unlocked file youve sent is the same as I generated with rcunlocker.
                                          what would change by flashing the main too?
                                          thanks for your help - appreciate it
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            Ack
                                            Ack
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
