Need Asus VivoBook X412DK Bios.
  • ciuz00best
    • Jun 2020
    • 20
    • Romania
    Mb: X412DK Rev: 2.1
    Bios: 25LB64CSIG
    Can someone provide me a dump. I couldn't find it anywhere so i'll try my luck here.
    I uploaded the dump.
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Need Asus VivoBook X412DK Bios.
    Try and report
    • ciuz00best
      • Jun 2020
      • 20
      • Romania
      Originally posted by Claudiomfa
      Try and report
      Thank you! IT works!
      • MICHAEL_2013
        • Feb 2016
        • 62
        • Colombia
        Thanks, Working perfect for me.
        • servis jaya.comp
          • Oct 2014
          • 33
          • Indonesia
          Try and report
          Hi Master..send for EC BIOS please....thanks...
          • peste
            • Dec 2016
            • 13865
            • ROMANIA
            try..
              • 22212
              • servis jaya.comp
                • Oct 2014
                • 33
                • Indonesia
                Originally posted by peste
                try..
                Tanks Master,,,,will try ...
                • tvquan66
                  • Sep 2022
                  • 6
                  • Viêt Nam
                  cpu locking 0.39Hz, can you help me?
                • bykanovm
                  • Aug 2022
                  • 98
                  • Украина
                  Please help me remove the password. X412DK Rev 2.1 board
                  Laptop model F412D
                  The sticker on the case is worn off, I can't see the serial number. A sticker on the board itself and the original BIOS. BIOS from the official website and the BIOS that I flashed above. They work, but the fan constantly spins at maximum speed.
                  • minhdigital
                    • Nov 2022
                    • 765
                    • Vietnam
                    Laptop model F412D
                    Send to you
                    • bykanovm
                      • Aug 2022
                      • 98
                      • Украина
                      Originally posted by minhdigital
                      Send to you
                      Thank you. works great!​
                      • joen_d66
                        • Apr 2013
                        • 72
                        • jakarta
                        Try and report
                        thanks master... it's working good
                        • GB1999
                          • Mar 2023
                          • 73
                          • Malaysia
                          please help disable the onboard RAM. below is the bios bin.
                          x412dk rev 2.1
                          • peste
                            • Dec 2016
                            • 13865
                            • ROMANIA
                            x412dk rev 2.1
                            post S/N, full name and model, etc.
                            • GB1999
                              • Mar 2023
                              • 73
                              • Malaysia
                              A412D
                              SN :KCN0CV131235518
                              • peste
                                • Dec 2016
                                • 13865
                                • ROMANIA
                                A412D
                                SN :KCN0CV131235518
                                try..
                                • GB1999
                                  • Mar 2023
                                  • 73
                                  • Malaysia
                                  try..
                                  thanks, but no display this bios bin
                                    SMDFlea commented
                                    Editing a comment
                                    Check for a hardware fix by changing ram configuration resistor straps.
                                • GB1999
                                  • Mar 2023
                                  • 73
                                  • Malaysia
                                  Do you have the way which resistors i need to remove and move.
                                • Tlamatini
                                  • Oct 2021
                                  • 12
                                  • México
                                  Hi friends, can anyone help me with my BIOS problem?
                                  I have an X412DK rev 2.1 with an AMD Ryzen. The laptop has no display. I’ve already tried a new BIOS from here and from the BC forums. It works to get the display image, but it doesn’t show the serial number and it doesn’t work with the removable RAM — only with the onboard RAM. This seems to be a BIOS problem. If needed, I can upload the original file for further help.
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • pirati
                                  by pirati
                                  10-27-2025, 04:20 PM
                                  ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                  This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                  09-07-2024, 02:50 AM
                                • lrouw84
                                  by lrouw84
                                  Hi there,
                                  01-28-2023, 01:31 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
