Asus X441UA Admin password
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Hello Guys, I'm back. I really have zero knowledge on how to modify or edit bios file/bin. So I hope you guys can help me once again.
    I have here an Asus x441ua-ga081t (i3-7100 variant) with a failed hard drive. So owner bought a Sata SSD for replacement. Unfortunately, laptop wont boot to any usb device. When entering bios, it's asking for password. I can enter uefi bios by pressing just enter or leave it blank on password screen.
    I immediately notice that I'm just a guest or a user because most of the options are greyed out. I cannot even change boot sequence. I also checked "SECURITY" tab and it shows the "ADMINISTRATOR PASSWORD STATUS" is Installed. So at this point I knew that bios needs to be modified.
    Owner explained that he can still boot to old hard drive but it is very slow and hard disk sentinel shows failure status. He also mentioned that a month back asus winflash updated his bios to version 324. Upon searching the net I don't see this version of his bios. 316 is the latest that I found.
    I uploaded bios file from chip w25q64fvsig. This is a working one but with admin password installed.
    Another thing, the Alt+R or rescue password method no longer works with this model. Thanks very much. Hope to hear from you guys soon.
  • peste
    • 12835
    • ROMANIA
    Re: Asus X441UA Admin password
    try..
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      Thanks very much for the fix peste. It worked perfectly. I can now modify options in bios and even select boot device order. The Admin security status shows "not installed". Now I can reinstall windows on this device. Thanks again! Cheers
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • fx1982
        ASUS ZEPHYRUS G16 GU605MV bios Admin password remove pls
        by fx1982
        Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
        It's a 2024 Asus Zephyrus G16
        GU605MV
        SN: S2NRCX035924088
        CN: AEDW
        MFD: 2024-02 36M
        BIOS VERSION: 315...
        06-05-2025, 10:46 AM
      • deividasASD
        ASUS ExpertBook B1500C Bios admin password
        by deividasASD
        Hello, forgot bios admin password, computer was bricked with bsod, only microsoft account backup code helped to reinstall windows. Tried finding admin password, various tools nothing helped.
        B1500CEAE-EJ0357R
        SN: M8NXCV023698317...
        08-31-2024, 05:19 AM
      • futadmytro
        Asus g713qm-es94 stuck on boot bios problem
        by futadmytro
        sn^M4NRKD02753616E
        MB- g533-6050a3250201-MB-A03
        Stuck on boot after ROG logo, did not enter to bios
        In flash bios , laprop boot but have video issue
        orig bios...
        06-25-2025, 08:07 AM
      • traxformania
        TONGFANG "GM7TG7P" Bios Password Problem?
        by traxformania
        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
        I'm trying to reset my bios without success.
        I tried :
        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
        11-15-2023, 07:32 AM
