i need Hp Dx2420 bios dump
  • kingnizarios
    • Apr 2020
    • 21
    • Tunisie
    hiii please help i need bios for hp dx2420
  • cheeky2
    • Dec 2012
    • 337
    I did a silly thing and flashed within Windows and didn't work. I have read my corrupted bios see attached file. Just now need a working bios dump for the Compaq /HP Motherboard dx2420 MicroTower. Not bothered which version of bios it is as I will update in Dos now instead of windows.
    The original version of the bios was 5.18 and after flashing via windows had no output from the screen after reboot!
    Had a look around on the web without any luck
    Thanks in advance
  • cheeky2
    • Dec 2012
    • 337
    Strange I was convinced I uploaded the bios file and put this information in a new post!
    I have managed to sort it out now. But I will upload my corrupted file and my modified file with slic 2.1 cert with xeon supported cpus as well :0
    Just make sure to flash with award software in dos bootable usb flash drive using rufus using command line awardflash bios.bin
    • cheeky2
      • Dec 2012
      • 337
      The Motherboard is a MS7525 Ver:1 which I am sure I put that information in the title of the New Post! I don't understand how it has been merged with this old post from someone else. I guess the moderator has merged it.
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
        by haitham sharabati
        Hello engineers 😀,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
        💀 Problem:😅
        - Device shows “Administrator Password”...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
