Asus GL752VL rev 2.1 bios
  • bilen
    • Aug 2014
    • 637
    • istanbul
    problem no screen
    Need working clean me bios .
    my old bios :
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Asus GL752VL rev 2.1 bios
    Originally posted by bilen
    problem no screen
    my old bios :
    try..
    • bilen
      • Aug 2014
      • 637
      • istanbul
      Originally posted by peste
      try..
      thank you working
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • Technodoc
        ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
        by Technodoc
        Asus laptop G614JZ-N3012W Rog Strix with i7
        Mainboard G634J-PMV-VGT
        6050A3441302-MB-A01
        2023-02-10
        Power button works okay....power light goes on
        Red "bottom" leds go on
        Charging led works
        Fans do not spin, capslock key does nothing, screen stays black
        I would like to program the bios again, to rule out a corrupted bios.
        However I run into a size error
        The bios chip is a Winbond 25R256JVEN
        Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
        02-24-2025, 04:46 AM
      • TyMercer
        Can I flash a working BIOS from one computer to another of the same make, model, etc?
        by TyMercer
        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
        11-13-2025, 09:39 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
