Asus GL752VL rev 2.1 bios
  • bilen
    • Aug 2014
    • 632
    • istanbul
    problem no screen
    Need working clean me bios .
    my old bios :
  • peste
    • 12719
    • ROMANIA
    Re: Asus GL752VL rev 2.1 bios
    Originally posted by bilen
    problem no screen
    my old bios :
    try..
    • bilen
      • Aug 2014
      • 632
      • istanbul
      Originally posted by peste
      try..
      thank you working
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • Technodoc
        ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
        by Technodoc
        Asus laptop G614JZ-N3012W Rog Strix with i7
        Mainboard G634J-PMV-VGT
        6050A3441302-MB-A01
        2023-02-10
        Power button works okay....power light goes on
        Red "bottom" leds go on
        Charging led works
        Fans do not spin, capslock key does nothing, screen stays black
        I would like to program the bios again, to rule out a corrupted bios.
        However I run into a size error
        The bios chip is a Winbond 25R256JVEN
        Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
        02-24-2025, 04:46 AM
      • fauxkalel
        ASUS Vivobook P1504F X512FA (MB X512FF) Working BIOS with DMI/SN
        by fauxkalel
        MB X512FF rev. 2.2
        i have laptop which during BIOS Update from Windows Update in some way broke dump -not working sound, Intel OED code 10 ("fw did not send fw ready notification").
        I need clean dump with inserted SN and other DMI data from my BIOS and sticker. Not sure if Win key is in BIOS.
        Is there way to build BIOS from update file? I tried extract it in many ways and find paterns from original dump but i think its not so easy like some time ago.. xD
        SN: L1NXCV10B90903C...
        10-29-2024, 03:34 AM
