asus eee pc 1015p rev 1.3g
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    this laptop has a strange problem, sometimes power button works sometimes not
    the power button is ok
    and sometimes the power led will lit , and after pressing power button , it lits brighter but no power on
    i reflashed bios with no success
    here is my bios file:
    is there any bios for it?
    thanks
    • 20977
    Re: asus eee pc 1015p rev 1.3g
    https://www.asus.com/Laptops/Eee_PC_...HelpDesk_BIOS/
    • mazloum
      • Sep 2012
      • 499
      • Lebanon
      thank you very much
      • mazloum
        • Sep 2012
        • 499
        • Lebanon
        i got a problem after programming new bios in a new chip:
        Boot Block Compatible Version Ver. 036
        If you want to recovery from USB device,
        please do not insert any disc into CD-ROM and Floppy!!
        Bad BIOS checksum. Starting BIOS Recovery...
        bios may be crashed. press y to recovery bios
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • lrouw84
          by lrouw84
          Hi there,
          01-28-2023, 01:31 PM
