asus eee pc 1015p rev 1.3g
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    this laptop has a strange problem, sometimes power button works sometimes not
    the power button is ok
    and sometimes the power led will lit , and after pressing power button , it lits brighter but no power on
    i reflashed bios with no success
    here is my bios file:
    is there any bios for it?
    thanks
    • 22279
    Re: asus eee pc 1015p rev 1.3g
    https://www.asus.com/Laptops/Eee_PC_...HelpDesk_BIOS/
    • mazloum
      • Sep 2012
      • 504
      • Lebanon
      thank you very much
      • mazloum
        • Sep 2012
        • 504
        • Lebanon
        i got a problem after programming new bios in a new chip:
        Boot Block Compatible Version Ver. 036
        If you want to recovery from USB device,
        please do not insert any disc into CD-ROM and Floppy!!
        Bad BIOS checksum. Starting BIOS Recovery...
        bios may be crashed. press y to recovery bios
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
