Need Asus K52JC Rev 2.1 BIOS
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello ,
    I need a dump for Asus K52JC Rev. 2.1, can someone help?
    Old Bios is attached
    Thanks in advance
  • peste
    • 12398
    • ROMANIA
    Re: Need Asus K52JC Rev 2.1 BIOS
    try..
    • dmartins
      David M
      • Apr 2014
      • 197
      • Lisbon
      Thanks @peste , its working !
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • oragano
        ASUS ex-b250-V7 motherboard bios corrupted - by me
        by oragano
        hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
        So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
        i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
        10-17-2024, 02:53 AM
      • chudofermer
        Asus Ally rc71l bios
        by chudofermer
        Hello!
        Received Asus Ally rc71l with the wrong bios.
        Have the original package and all serial numbers.
        Can anyone help me understand what is wrong?
        Condition:
        Received with an original box with all serial numbers
        Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
        Got the flash dump, nothing found on DMI section
        No Windows key, just key ID on the box
        What is done:
        1. Flash the latest bios version with serial numbers...
        03-05-2025, 05:42 AM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
