Hi Flea! been reading this thread and the other one specifically for Lenovo T495 (FA495 NM-C131)..
i performed your instructions on the 1st post, but did not seem to work. Black screen and some tones (somewhat like musical) is all I got along with fan spin. Got a bit anxious as I read a post from someone that even his backup dump was not able to restore the laptop's original state. Luckily though my backup dumps managed to restore it so I'm back to square one of having power-on bios password..
any chance you could assist me on getting a good patch for this laptop?
here's the backup dump that i usedComment
There are a few exceptions, I have this T495 on my list of compatible models:
ThinkPad T495 (TYPES: 20NJ and 20NK)
@esprugodoys
Have you tried to flash back Original BIOS in order to check that you have a “good” backup?Last edited by AAAC; 08-23-2022, 02:10 PM.Comment
Is there anyone who can give a detailed description on how to clear supervisor password on AMD based T14?Comment
lenovo t480
Attached FilesComment
yes. my backup dump is good, the one i attached on my previous post that is the backup that i used. laptop is back to its original state now which has a Power-On/bios password using that dump.
this particular model is Type 20NK as indicated on the sticker at bottom cover.Comment
@esprugodoys
Can you go into Setup/BIOS? Power-on the laptop, press F1 key to go into Setup, when asked for password just press ENTER key, if it lets you get in (in read-only mode) go to Security and check Supervisor Password status.Comment
Laptop just shuts down after 3 incorrect attempts on the password prompt.
since the Power-On password is enabled, it would be safe to assume that Supervisor Password is Active or Enabled?Comment
@esprugodoys
Most probably it's the Supervisor Password Active, unless you haven't reset CMOS by disconnecting all source of energy and also disconnecting CMOS battery.
So if you Original BIOS is good and safely stored, have you tried to look for a T495 patched BIOS to try? This patched bios is only used for the unlock, after that you will use the Original BIOS.Comment
@esprugodoys
got it to work now.. just finished installing a new OS on it.
details i sent to your inbox.. Tnx a lot!Comment
Hello again,
first of all thanks for checking my bios file.
Why Am I not able to patch it myself?
Still the same problem, autopacher works, there is information about new bios file created, but the file doesn't egsist in shown source.
Even I tried to patch someone's bios file updated on this forum - the same problem.
Software here: Wind10, Python 3.10.Comment
The X260 has a W25Q128FV as SPI Flash which is packaged as WSON8. Although the pins are visible as small bullets, there is no way to produce a dump by using a clamp. If you would have used a TL866II instead of a CH341A the programmer would have told you that there is a contact problem. I was not able to produce a dump even by using pogo pins. With WSON8 there is only one way: desoldering.
Lenovo stopped this stupidity and starting with the X270 they used again SO8 packaging.
For the patched BIOS you can use the binary of an arbitrary X260. But after removing the password you need your original BIOS, so you need a verfied dump. By verified I mean: produce as many dumps until two consecutive dumps are identical (fc /b dump-A.bin dunp-B.bin).
Good luck.Comment
hello need help
lenovo p52s patched bios supervizor passwordComment
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory defaulTComment
https://www.badcaps.net/donateComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
