 I have done today T470S and T460s. everything work flawlessly
 big thanks guysComment
 Try ....Attached FilesComment
 Downloaded, unzipped, python installed, but after trying to run autopatch.cmd, it starts and closes straight away. What is causing this?Comment
 Good day to all - I hope you're doing well.
 This is my first post, so it might get a little winded. As a novice, to all things bios, this entire process seems a bit daunting,
 but unperturbed "I endeavor to persevere".
 Last year - from a recycle outlet - I received a couple of Lenovo laptops - T460s 20FA, and an X220 - with bios password.
 I can use the X220 - which I am now - but not the T460s. Luckily I Googled, and found you fine folks. YAY!
 Since then, I've been trolling this site - for a couple of months - with the exception of the holiday season - Happy New Year! -
 trying to obtain as much knowledge as possible to remove the bios pswd, and to avoid asking questions,
 that will most likely be ignored by all of you fine individuals.
 Believing I had ascertained the requisite knowledge, I decided to scream JERONIMO!
 My test laptop is the Lenovo X220, running Windows 7 Pro 32bit.
 I have purchased - what I believe is the prerequisite hardware - a test Clip Board EEPROM BIOS Programmer CH341A.
 1) I have downloaded and installed AsProgrammer_2.0.0a14; Colibri (not sure yet if needed); lenovo_autopatcher_0.2;
 NeoProgrammer V2.2.0.8; Phyton 3.8 (not sure if it’s installed correctly); and UEFITool_0.28.0_win32.
 2) I've also downloaded "Patched T460S ME_CLEAN", which I haven't done anything with as of yet.
 3) I've extracted - 3 times without error - the original -as far as I know - bios image from a Winbond W25Q128FV bios chip on the T460s (20FA).
 4) I have placed a copy of the original bios .bin - named "tp460sbios.bin" - in the lenovo_autopatcher folder, then pressed shift,
 and using my mouse, right clicked on autopatch.cmd, but only a cmd window flashes on screen.
 No additional output is produced – so my dilemma – I’m not sure how to procced next.
 What I’ve been having difficulty finding, and I'd like - if you all would be so kind – is for someone to provide me with a link,
 or tutorial that can help me accomplish the task at hand, without my interrupting – any further – the excellent work you're accomplishing – meant sincerely – without me asking inane questions – as if this post isn't already.
 Much appreciated any, and all assistance, positive, and or negative.
 Thanks,
 deviouswun.
 Moderator – if this post is misplaced, please place it where you see fit, or just let me know where you’ld like me to stick it. Last edited by deviouswun; 02-03-2022, 04:33 PM. Last edited by deviouswun; 02-03-2022, 04:33 PM.Comment
  Wow! That was quick. I appreciate your illuminating reply Wow! That was quick. I appreciate your illuminating reply
 Thanks  Comment
 ...test itAttached FilesComment
 ***SOLVED***
 ...was needed to fill any pwComment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
