  • AAAC
    • Jan 2020
    • 458
    • Mexico
    #881
    @mysticusa
    You need a bios chip programmer, you can use CH341A (first make sure stock software does not corrupt reading/writing, if it does, use alternate software), EZP2019 or other programmer. Besides programmer I also recommend a SOP8 clip to prevent desoldering/soldering of bios chip. Some ThinkPad models use a WSON8 chip, which would prevent the use of clip, in this case you can solder wires from chip to programmer PCB adapter.
    What’s the ThinkPad model number?
    • mysticusa
      • Feb 2021
      • 11
      #882
      Originally posted by AAAC
      @mysticusa
      it s t480s,
      one of our office worker was given this to do remote work during lock down, he had a problem with his ssd, so when i changed the ssd, and tried to boot with usb for new install, i couldnt do f12, went to bios found SVP so cant change anything (edit: worker doesnt remember setting it up, but we never put svp so gotta be someone from his house, or himself lying). I can use usb nvme enclosure to do the job one way or another but was thinking of finding out easy reset procedure. thought this was easy seeing no mention of bios soldering etc... anyways i think i ll look into your suggestion as a future consideration as well, i ll make sure SVP these laptops before handing them over to remote workers next time
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        #883
        @mysticusa
        It’s a relatively easy job, as long as you use a programmer with SOP8 clip (no soldering required). With some experience it can be done in 30 minutes or less.
        In my opinion the most important step is having a backup of original BIOS (read chip and save file, do this 3 times and compare all 3 files to make sure they all match), before trying any patching of the bios.
        • solowalker007
          • Sep 2021
          • Central African Republic
          #884
          Hello I have Lenovo Yoga X390 have bios password. I need help please.
          • mysticusa
            • Feb 2021
            • 11
            #885
            @mysticusa
            It's a relatively easy job, as long as you use a programmer with SOP8 clip (no soldering required). With some experience it can be done in 30 minutes or less.
            i ll keep a note of this. and thank you for the help. problem is solved actually without needing anything else... worker provided possible passwords he thought set up. and i tried them with caps on and off, one of them worked... he set up with caps on so i tried by hunch and figured it out. but future issues i ll keep on this.. maybe buy a model with locked bios and figure out with the programmer for practice.
            • Maggiore
              • Sep 2021
              • 27
              • Ukraine
              #886
              Hi, pls help. Need un-password.
              • ak1_2004
                • Oct 2017
                • 42
                • Iran
                #887
                Lenovo E470
                Dump Bios + Patched Attached !
                When I used patched bios ! Laptop dont show anything on lcd !
                thanks
                • Maggiore
                  • Sep 2021
                  • 27
                  • Ukraine
                  #888
                  Thank you all, I did it myself, it works.
                  • bassbabu368
                    Banned
                    • Oct 2018
                    • 49
                    • india
                    #889
                    Originally posted by ak1_2004
                    Lenovo E470
                    thanks
                    this just falsh it try
                    • lolito2011
                      • Jun 2016
                      • toluca
                      #890
                      Please need unlock Thinkpad L460 8MB
                      • shabi
                        Banned
                        • May 2019
                        • 147
                        • pakistan
                        #891
                        STEP 1: Flash and replace current BIOS with the generated patch file
                        STEP 2: Boot the machine
                        STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                        STEP 4: Enter any character when asked for Supervisor Password
                        STEP 5: Press enter when it shows Hardware ID
                        STEP 6: Press space bar 2x when asked
                        STEP 7: Turn off machine
                        STEP 8: Restore original BIOS
                        STEP 9: Reset BIOS settings to factory defaulT
                        • ak1_2004
                          • Oct 2017
                          • 42
                          • Iran
                          #892
                          thx
                          worked
                          • dinarte
                            • Sep 2021
                            • 13
                            • Brazil
                            #893
                            new user here.
                            so, as i understand, i need a bios chip programmer, desolder my bios chip, put it in the programmer, read it and upload it here. then someone can send me a patched archive that i need to write on the chip and will be able to bypass the password verification, right?
                            does it work for the intel T14 GEN 1?
                            • munir100
                              • Dec 2018
                              • 188
                              • uae
                              #894
                              3rd generation thinkpad x1 yoga bios password
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #895
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • dinarte
                                  • Sep 2021
                                  • 13
                                  • Brazil
                                  #896
                                  Originally posted by dinarte
                                  new user here.
                                  i've been reading all the posts.
                                  i seen some people talking about "self healing" bios on some models. Is the t14 one of those models? i haven't seen anyone talking about this specific model.
                                  if it helps, my configs are
                                  i5 10310u (vpro)
                                  8gb ram
                                  • zomi
                                    • Nov 2011
                                    • 511
                                    #897
                                    Yes the t14 series are self healing.
                                    • dinarte
                                      • Sep 2021
                                      • 13
                                      • Brazil
                                      #898
                                      So there is no solution?
                                      • dinarte
                                        • Sep 2021
                                        • 13
                                        • Brazil
                                        #899
                                        i don't even need the bios password, i just need to reset the 0199 error count. just to be able to boot again
                                        • AAAC
                                          • Jan 2020
                                          • 458
                                          • Mexico
                                          #900
                                          @dinarte
                                          To be able to reset “Error 0199: System security-Security password retry count exceeded” you need to get into Setup/BIOS with Supervisor Password.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            Yesterday, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
