  • mersudin
    • Mar 2014
    • BiH
    #3901
    I have problem using this tool on Lenovo L590, type 20Q8-2DN645 serial PF2DN645 , i tried patched PATCHED_CLEANED and it boots but asks for supervisor password, if i enter anything it says wrong. Can someone check or patch it
    • danito
      • Jun 2016
      • 1097
      #3902
      the password is in ITE not in bios
      • softlibs
        • Jul 2025
        Ok, so I have Lenovo Thinkpad X1 Carbon Gen 5
        type: 20K4-01XUS
        Serial PF-0VQQ8V
        i've been searching this thread for a patched version and the only one i found the link said invalid file or something.
        i've been using the patched bios posted to clear supervisor passwords on two dozen laptops now.
        for some reason, autopatch fails with bad bin file every attempt. but i can dump the original bios, program the patched version (downloaded from this thread), remove the password, reprogram the original dump, then celebrate.
        i was also able to use the t560 patched bios to remove the password on a p50s since it is the same motherboard
        will be learning the ec technique next as i have a few x1 carbon gen 7 and 8 to unlock. i did post about nuking a p53s i'll get back to that one later
        • balu457157
          • Oct 2015
          • 19
          • India
          #3904
          LENOVO THINKPAD T495 AFTER PATCHED BIN LAPTOP GETS BEEP AND BLANK SCREEN.
          • stakrzysiu
            • Sep 2016
            • 18
            i have an Lenovo Thinkpad T470s which is registered to a company.
            Can somebody help me to delete this?
            Model : T470s
            Type: 20HG-S1V700
            SN: PC-0M31J3
            Thank you very much.
            • dogv
              • Aug 2025
              • uk
              #3906
              Massive thank you for this. It worked a treat.
              • softlibs
                • Jul 2025
                ok so never mind my post above because i found a patched version for the x1 carbon gen 5 that i could download. i'm working on gen 6 now.
                i was having trouble with autopatch always having a problem with my dumps. i've been using ch341 programmer on linux. it was writing everything fine, but none of the dumps would patch.
                i've been trying to figure out how to clean the me region, and had to switch back to windows, and in the process, dumped this x1 carbon gen 6 with asprogrammer. autopatcher patched it without complaining. i'm writing it to the patient right now.
                • mfeti
                  • Dec 2022
                  • Lithuania
                  #3908
                  Could anyone help me to clear password from Thinkpad E495 Ryzen 3?
                  Model: Lenovo Thinkpad E495
                  MB: FE495 NM-C061
                  SN: L1HF9AD023B
                  I've tried autopatcher but it doesn't work with this model
                  Bios and EC attached
                  • Markus1741
                    • Sep 2020
                    • 948
                    • N/A
                    #3909
                    MB: FE495 NM-C061
                    SN: L1HF9AD023B
                    Hello you can try this new patched file ....
                    • Kiki Cares
                      • Feb 2022
                      • 29
                      • Nigeria
                      #3910
                      I guys,i have Lenovo T470
                      bios password
                      pls guys help me
                        SMDFlea commented
                        Editing a comment
                        The serial number should be posted with every bios request. Did you try the patcher at post 1 it works ok for T470
                    • mfeti
                      • Dec 2022
                      • Lithuania
                      #3911
                      Thank you! Works perfectly, password cleared. Will compare the files to understand how to unlock other machines. THANKS!
                      • didouche1200
                        • Oct 2016
                        • 367
                        • 82679911441
                        #3912
                        PLEASE NEED UNLOCK THINKPAD P16S GEN 1
                        SN PF3TCCDW
                        TYPE 21CL
                        • vidvansh
                          • Mar 2025
                          • 26
                          Need help removing BIOS password from my Lenovo T480s 20L8
                          Serial : PC0V3ZRN
                          Motherboard: ET481 NM-B471 Rev 1.0
                          I tried using the patched but after programming the chip. Laptop did not turn ON and when i connect charger. Power button flash 3 times and then nothing happens. I programmed back the original file but it showing the same symptoms.
                          I removed the chip from the motherboard.
                          20L8-S4S00
                          • cris_carriaga
                            • Jul 2013
                            • 29
                            • philippines
                            #3914
                            please rebuil repair and clearme
                            and please patch also
                            lenovo thinkpad e490
                            SN-PF-1k0mxe
                            NM-B911
                            • Holstein
                              • Aug 2025
                              I have a T480s running Windows 11, everything is working, but the BIOS is locked. So I purchased a CH341A programmer, read the chip 3 times to make sure it's right, and then patched it with the auto-patch tool. Unfortunately, the laptop refused to boot and played a melody. I had to write the original bin into the chip; otherwise, I can not use my laptop.
                              Would like to know why and how to patch it properly, files provided.
                              Model: T480s
                              Type: 20L8-S62100
                              SN: PC-11AMW1
                              • Holstein
                                • Aug 2025
                                Serial : PC0V3ZRN
                                20L8-S4S00
                                I suggest you remove the battery, unplug the button battery, wait a minute, and then plug the button battery and main battery back. Now you should be able to post. That's how I solve similar situation today.
                                • rafaellguerra
                                  • Jul 2025
                                  • Brazil
                                  #3917
                                  I have one Lenovo X395 (japanese) and need remove Supervisor Password.
                                  I read my BIOS (25Q80DVSIG) but I get a error when try to patch (BIN and HEX).
                                  Model: X395
                                  Type: 20NM-S1PG00
                                  SN: PC-1FBBDX
                                  • Stefan Steff
                                    • Mar 2024
                                    • 367
                                    #3918
                                    Model: X395
                                    Type: 20NM-S1PG00
                                    SN: PC-1FBBDX
                                    Try with UC3 (near WWAN1 connector) and if it's W25Q128FWSIQ then it works with 1.8V
                                    • kskoba
                                      • Aug 2025
                                      Thanks for your work on this.
                                      I can't seem to get the patched BIOS to work.
                                      I'm working on a Thinkpad T480.
                                      S/N: PF1HZZPP (on sticker on case), System-unit S/N in BIOS is PF1LEPXM
                                      Motherboard: NM-B501
                                      BIOS Chip: Winbond 25Q128JVSQ
                                      I selected the W25Q128JV chip type in AsProgrammer.
                                      Downloaded the BIOS x 2, compared hash values and it was good.
                                      Applied the patch.
                                      After flashing the patched BIOS I just get the loud musical tune and a black screen. Never any words appearing.
                                      Re-flashing the original BIOS makes it work again, but it still has the BIOS password (as expected as I never did apply a successful patched BIOS).
                                      Any ideas? I had updated to the newest BIOS from Lenovo for the T480 before going through this. Could that be the issue? My BIOS version is: 1.55.
                                      I've attached my original BIOS and the patched versions.
                                      Thanks in advance for any help you can provide.
                                      • Stefan Steff
                                        • Mar 2024
                                        • 367
                                        #3920
                                        Applied the patch.
                                        Write the attached BIOS content and follow this steps:
                                        STEP 1: Flash and replace current BIOS with the attached file
                                        STEP 2: Boot the machine
                                        STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                        STEP 4: Enter any character when asked for Supervisor Password
                                        STEP 5: Press enter when it shows Hardware ID
                                        STEP 6: Press space bar 2x when asked
                                        STEP 7: Turn off machine
                                        STEP 8: Restore the Lenovo_T480_ME_Clean.bin file
                                        STEP 9: Reset BIOS settings to factory default
                                        STEP 10: Update your BIOS to the latest version
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
