  • mersudin
    • Mar 2014
    • BiH
    #3901
    I have problem using this tool on Lenovo L590, type 20Q8-2DN645 serial PF2DN645 , i tried patched PATCHED_CLEANED and it boots but asks for supervisor password, if i enter anything it says wrong. Can someone check or patch it
    • danito
      • Jun 2016
      • 968
      #3902
      the password is in ITE not in bios
      • softlibs
        • Jul 2025
        Ok, so I have Lenovo Thinkpad X1 Carbon Gen 5
        type: 20K4-01XUS
        Serial PF-0VQQ8V
        i've been searching this thread for a patched version and the only one i found the link said invalid file or something.
        i've been using the patched bios posted to clear supervisor passwords on two dozen laptops now.
        for some reason, autopatch fails with bad bin file every attempt. but i can dump the original bios, program the patched version (downloaded from this thread), remove the password, reprogram the original dump, then celebrate.
        i was also able to use the t560 patched bios to remove the password on a p50s since it is the same motherboard
        will be learning the ec technique next as i have a few x1 carbon gen 7 and 8 to unlock. i did post about nuking a p53s i'll get back to that one later
        • balu457157
          • Oct 2015
          • 19
          • India
          #3904
          LENOVO THINKPAD T495 AFTER PATCHED BIN LAPTOP GETS BEEP AND BLANK SCREEN.
          • stakrzysiu
            • Sep 2016
            • 18
            i have an Lenovo Thinkpad T470s which is registered to a company.
            Can somebody help me to delete this?
            Model : T470s
            Type: 20HG-S1V700
            SN: PC-0M31J3
            Thank you very much.
            • dogv
              • Aug 2025
              • uk
              #3906
              Massive thank you for this. It worked a treat.
              • softlibs
                • Jul 2025
                ok so never mind my post above because i found a patched version for the x1 carbon gen 5 that i could download. i'm working on gen 6 now.
                i was having trouble with autopatch always having a problem with my dumps. i've been using ch341 programmer on linux. it was writing everything fine, but none of the dumps would patch.
                i've been trying to figure out how to clean the me region, and had to switch back to windows, and in the process, dumped this x1 carbon gen 6 with asprogrammer. autopatcher patched it without complaining. i'm writing it to the patient right now.
                • mfeti
                  • Dec 2022
                  • Lithuania
                  #3908
                  Could anyone help me to clear password from Thinkpad E495 Ryzen 3?
                  Model: Lenovo Thinkpad E495
                  MB: FE495 NM-C061
                  SN: L1HF9AD023B
                  I've tried autopatcher but it doesn't work with this model
                  Bios and EC attached
                  • Markus1741
                    • Sep 2020
                    • 846
                    • N/A
                    #3909
                    MB: FE495 NM-C061
                    SN: L1HF9AD023B
                    Hello you can try this new patched file ....
                    • Kiki Cares
                      • Feb 2022
                      • 29
                      • Nigeria
                      #3910
                      I guys,i have Lenovo T470
                      bios password
                      pls guys help me
                        SMDFlea commented
                        Editing a comment
                        The serial number should be posted with every bios request. Did you try the patcher at post 1 it works ok for T470
                    • mfeti
                      • Dec 2022
                      • Lithuania
                      #3911
                      Thank you! Works perfectly, password cleared. Will compare the files to understand how to unlock other machines. THANKS!
                      • didouche1200
                        • Oct 2016
                        • 359
                        • 82679911441
                        #3912
                        PLEASE NEED UNLOCK THINKPAD P16S GEN 1
                        SN PF3TCCDW
                        TYPE 21CL
                        • vidvansh
                          • Mar 2025
                          • 21
                          Need help removing BIOS password from my Lenovo T480s 20L8
                          Serial : PC0V3ZRN
                          Motherboard: ET481 NM-B471 Rev 1.0
                          I tried using the patched but after programming the chip. Laptop did not turn ON and when i connect charger. Power button flash 3 times and then nothing happens. I programmed back the original file but it showing the same symptoms.
                          I removed the chip from the motherboard.
                          20L8-S4S00
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
