Yep, it worked with that one. Thanks a lot for the hint, really appreciated.
Will now try to write it back.Code:./autopatch X1CG5_WB25Q128.bin Using UEFIReplace to inject 2 DXE drivers... [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5) [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd) Looking for volumes to patch... [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h): Found volume at offset 800000h (checksum 2609h) Replacing volume. Done. PATCH FILE: X1CG5_WB25Q128_PATCHED.bin Good luck.
I did the autopatch for my T470S and when I turn on the laptop it plays a melody once and screen is back. Please see my original and patched BIOS files attached.
Thank youAttached FilesComment
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
try and follow steps from autopatcherAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
I tried my backup after the second failed attempt and it works fine, laptop turns on and I was able to go to the BIOS settings without an issue, however the supervisor password is still there. Just to double check, do I need to do anything to the file you sent me or just program the BIOS with it?Comment
It's the same laptop lol, I'm doing the firmware patching remotely, while freesofia is doing the hardware part. 😁 Thanks a lot for the help guys and sorry for the stupid question, it was our first time doing the procedure.Comment
it means your bios has problem with ME_Region. Try patched clean_ME bios and follow steps from autopatcher.
I tried my backup after the second failed attempt and it works fine, laptop turns on and I was able to go to the BIOS settings without an issue, however the supervisor password is still there. Just to double check, do I need to do anything to the file you sent me or just program the BIOS with it?Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
it's ok, I just was confused about who to reply. Enjoy, now you know what to do, usually bioses are containing 64, 128, 256 in the name, that one with 80 is for thunderbolt, don't touch it.
It's the same laptop lol, I'm doing the firmware patching remotely, while freesofia is doing the hardware part. 😁 Thanks a lot for the help guys and sorry for the stupid question, it was our first time doing the procedure.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
First off I want to thank you for your help. Unfortunately this one didn't work either. I checked the error tone with the Lenovo diagnostic app and it's 0285 TPM initialization error.Comment
I don't know the bios password, can you help me?Attached FilesComment
Hello everyone, I have tried to patch the bin file as the post says, resulting in an error when I use the patched file it issues an error whose code according to the Lenovo application is the number 0285 This error code refers to "error related to functionality compatible with TCG (it may be a TPM initialization error)", any help is appreciated by the laptop, these are the data:
lenovo e490
motherboard model FE490-FE590-FE480 NM B911 REV 2.0 2019-01-17
Type 20N9
Number standard PF1405GJ
Files attached both the original copy and the copy already patched with error 0285Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
 - Loading...
 but I don't get it, there are 2 of them with the same laptop?
