Just bought a CH341A programmer for Thinkpad T480s, IC chip is 25Q128JVSQ,
I used the AsProgrammer 2.1.0 .13 Version, But I cannot find this chip model in CH341A chip list, there are only 25Q128BV and 25Q128FV.
Can someone help how to handle this IC 25Q128JVSQ?
Thanks very much.Last edited by Vincehu; 01-07-2025, 08:36 PM.Comment
Hey,
Could someone help me with the patch?
I tried it because the BIOS was locked and after install the patch the Laptop just beeped 2x5times and the LCD keepes black.
Its a T440p type 20AN-00C1GE S/N PC01B4DD and here are the BIOS files:
Thank you.Attached FilesComment
I need patched bios
Lenovo Thinkpad X1 Tablet Gen 2
TYPE- 20JC-S00C00
S/N - R9-0N9023
15218-5 lgf-1Attached FilesComment
tryAttached FilesComment
for me, it doesn't work. BIN is patched, everything seems to work but as soon as I flash back the original dump, I still have the password. Any ideas what I did wrong?
Both files attached. Machine is a ThinkPad T450s 20BX-000XGE SN PC-04QAV8
Thanks!Attached FilesComment
hi
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter BOOT_CODE_XXXXX-Number given patched file
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
try and feedbackAttached FilesComment
Hello, I have a problem with my Lenovo ThinkPad E585 laptop (AMD Ryzen 5 2500U). I have a problem at this point in the manual:
STEP 4: Enter any character when asked for Supervisor Password
When I press F1, a screen is shown asking me to enter the password (on a black background, like a command line) but the keyboard stops working, no buttons on the keyboard work. I also tried to connect a USB keyboard - unfortunately the same thing happened. I tried to turn off and try to repeat all the steps again and again several times - but unfortunately nothing has changed, the laptop seems to freeze. When I restore the backup bios, everything works fine in Windows 10, the keyboard works, the laptop works without any problems (but the password in the bios unfortunately remains and I can't reinstall Windows). I also tried the already patched dump from the forum (post hoaca388):
https://www.badcaps.net/forum/troubl...s-dump-request
But the result is the same, you can't enter the password on the patched bios. Maybe someone knows a solution, what am I doing wrong?
Tried the prcedure twice, sadly still the same... Is there a difference between supervisor and boot password for patching? Because it seems that it's the boot password on the machine.
hi
try and feedbackComment
Can someone please patch this file for me ? Because i cant open patcher.Attached FilesComment
Read the rules https://www.badcaps.net/forum/troubl...before-posting , what is it ? post the full laptop model number and serialComment
I have a P50 and I am also having the same problem. After flashing the patched Bios, the laptop doesn't boot. The power button light turns on, the fan spins, the screen stays black, and after a minute or about 75 seconds, it just turns off.Hi Everybody! Until now I have been able to unlock a couple of Thinkpads thanks to this system which I think is quite easy and straight-forward.
Anyway now I came across a P50, and it seems that autopatcher is NOT working: if I patch the BIOS, laptop boots up for 5/6 seconds but then it shuts OFF. NO video screen, NO beep codes.
What I did: dumped the file using a clamp (dumped twice, checked using certutil and generated same hash file so I moved on); patched with autopatched, loaded new BIOS. tried 3 times, same results...
Can it be because of the MACRONIX chip? That is the 1st one I am finding (previous ones were Winbond). Attacched original DUMP.
If I write the original Bios back, it boots normally.
Did you find any solution for this?
I am attaching the original dump and the patched one. Can anyone please help me?Attached FilesComment
Sorry, I forgot to give more details about the P50 in my first post.
ThinkPad P50
Machine Type Model: 20EQ-S20D00
Serial number: PC-0SWU6L
18/02
In my previous post, I attached the original dump and the patched file. I patched it using the autopatcher, but the laptop unfortunately doesn't boot with it.
Thanks for any help.Comment
I was able to fix it, using another P50's patched file. It took a little bit time, and it restarted a few times, but eventually it did boot and I could remove the password.
ThinkPad P50
18/02
Thank you anyway.Comment
Can someone patch me this pls, everytime i patch it the laptop only beeps the whole time.
it had a supervisor Pw .
Lenovo Thinkpad X1 Yoga Gen 4Attached FilesComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
working 100%
