  • bigboots
    • Mar 2019
    • 43
    • uk
    #3141
    Originally posted by pdblues2231
    hi,
    try this..
    Thank you for the time. It did not work need to flash the ec.
    • kubernet
      • Jan 2024
      • 9
      • Suisse
      #3142
      Hello
      on T470S, i weld the unluck bios chip, do all the procedure, but when i sold original bios, still asking for password
      do you have any help ?
      thanks
    • bondminer009
      • Nov 2023
      • 48
      • Malaysia
      #3143
      Good day,
      I would like to share, after follow the instruction all working well.
      but now, the laptop only take longer time after pressing F1 menu, only "Entering Bios Menu" and after few minutes "laptop hang"
      Model laptop : T470s
      Serial : PC0NTV4P
      Board type : 20HG-S07D0K
      Using UEFIReplace to inject 2 DXE drivers...
      [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
      [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
      Looking for volumes to patch...
      [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
      Found volume at offset 800000h (checksum 2609h)
      Replacing volume.
      Done.
      PATCH FILE: lenovo2_PATCHED.bin
      Good luck.
      above detail information, I can share it, need advise and need help how to handle this case
      thanks
      Three
      • danito
        • Jun 2016
        • 1259
        #3144
        Originally posted by bondminer009
        Good day,
        Serial : PC0NTV4P
        Replacing volume.
        Done.
        Good luck.
        thanks
        Three
        try
        • bondminer009
          • Nov 2023
          • 48
          • Malaysia
          #3145
          Originally posted by danito
          try
          still the same, still lock (bitlocker)
          • danito
            • Jun 2016
            • 1259
            #3146
            reinstall winodws, BitLocker Drive Encryption, or BitLocker, is a Microsoft Windows security
            • bondminer009
              • Nov 2023
              • 48
              • Malaysia
              #3147
              Thanks, unfortunately can’t do anything, boot menu also can’t appear.
              • danito
                • Jun 2016
                • 1259
                #3148
                Can you get into the bios? Do you still have your password?
                • bondminer009
                  • Nov 2023
                  • 48
                  • Malaysia
                  #3149
                  No. The steps details, power on - lenovo logo appears - press enter - and only bitlocker passcode needed - and if 3x times failed laptop shutdown.
                  unfortunately, I don’t have the password.
                  Another laptop have bitlocker code, but didn’t work.
                  • bondminer009
                    • Nov 2023
                    • 48
                    • Malaysia
                    #3150
                    Good day,
                    Serial : PC0NTV4P
                    Replacing volume.
                    Done.
                    Good luck.
                    thanks
                    Three
                    Finally, I can fixed these issue. I will update in this forum today.
                    Thank you ✌️
                    • bondminer009
                      • Nov 2023
                      • 48
                      • Malaysia
                      #3151
                      Good day,
                      Serial : PC0NTV4P
                      Replacing volume.
                      Done.
                      Good luck.
                      thanks
                      Three
                      Follow step by step - ( thread "LENOVO BIOS AUTO-PATCHER ")
                      and I did another step
                      - Delete / erase program BIOS
                      - Re-programming using original T470s working bios (attached for original working bios)
                      and working well
                      Thanks​
                      • css100
                        • Mar 2024
                        • Austria
                        #3152
                        Knucklegrumble
                        thanks for sharing this tool and the instruction,
                        it works great an a Lenovo L480 (25Q128JV) to reset the password
                        • kodox
                          • Jul 2017
                          • 329
                          • Indonesia
                          #3153
                          thank's for making the process alot simpler @Knucklegrumble,
                          the tool you made is working to remove supervisor password on
                          Lenovo ThinkPad L13 with machine type 20R3 but, with some issues
                          that later i came across with my own solution & i wanna share
                          my solution that worked for me, because i've searched the net and
                          no one come with the solution.
                          after flashing patched bios to the chip i ignored message that said:
                          2204: System configuration data is invaid
                          and continuing the process that described on page 1, after re-flashed
                          original bios back to the chip the error message still exist, i thought
                          because i haven't done the "restore default" menu in bios and not attached
                          anything to the motherboard except screen, charger and usb keyboard
                          after restoring default in bios the error message still there and i still
                          ignored that, put back all together, set the date & clock and leave everything
                          on default value, exit the bios and before it boot to window the error 2204
                          emerge and halt the boot process, ask me to press ESC to continue and i did,
                          booted to window normaly and everything okay in windows, restart and error
                          2204 is halting again, asking to press ESC to continue (this time it get
                          my attention though). everytime the laptop turned on (cold boot or warm boot) always
                          halted by error 2204.
                          checked all serial in bios information it's all there, not invalid or missing.
                          i did all the steps on adding or editing DMI info using tool in
                          https://www.badcaps.net/forum/troubl...=5#post1622424
                          everytime i try to add using the tool it's always said "Data of the same device type is already in EEPROM"
                          searched for reference on error 2204 and found nothing related to my problem,
                          after intense nerf fighting i decide to take a risk that would brick this Thinkpad L13,
                          this is what i've done:
                          1. build bootable fdd using "Lenovo Gold Key U1 Tool", i followed instructions till creation using u1.exe
                          2. booted the fdd and choose top of the menu (forget to take picture)
                          3. press any key after choosing the top menu
                          4. i followed instruction coolshrimp here https://www.badcaps.net/forum/troubl...74#post1711774, i think the instruction from coolshrimp a bit different but, the main goal is the same, to empty stored data on eeprom & enter same data but with diferent "aproach" using the tool (i think), just remember to read the S/N first and take a picture of it, cause you'll need reenter those exactly the same as it was
                          5. after initializing eeprom chosen, the process could take 40-60 seconds so be patient and don't interupt
                          6. when done initializing it will ask to enter serial number, enter the "C0" section from the picture you take exactly the same
                          7. after that it will generate UUID & brand name, just choose "yes"
                          8. after done and pressing enter, it will go back to S/N utility. if not just try to explore one by one menu until you found it, in S/N utility choose "add S/N" and choose "B0" then enter serial from the picture you take exactly the same
                          9. choose exit from sub menu until main menu choose exit (shutdown)
                          10. done
                          sorry for the long story, hope it helps
                          • Marcialle
                            • Mar 2024
                            Im confused as to what steps i am suppose to take. Do i just take these files and run them or am i suppose to flash it to a chip or something. Their are no written instrucions and i dont know what i am doing. (moments written before disaster) LOL
                            • Dmitriy Geels
                              • Mar 2024
                              Originally posted by Dmitriy Geels
                              Hi everyone!
                              I'm looking for a replacement MB for old lenovo L580.
                              There are some options to buy one with boot password. Can this tool help in removing it?
                              I have original motherboard functioning, but with dead charging port -- can be used to read EEPROM.
                              It can. I can confirm now, boot password can also be removed.
                              • AAAC
                                • Jan 2020
                                • 459
                                • Mexico
                                #3156
                                Originally posted by freeman2006
                                Please remove superviser password amd computrace. Lenovo X1 Carbone 7th generation type 20qd-00l1uk sn:pf-1zggh7. When patch with autopacher and return dump computer only beeping continiute.
                                LENOVO BIOS AUTO-PATCHER only works up to ThinkPad X1 Carbon Gen 6 (20KH, 20KG)​, your X1 Carbon is Gen 7, that's why.
                                • ingus16
                                  • Apr 2024
                                  #3157
                                  redacted
                                  • kordex35
                                    • Apr 2015
                                    • 49
                                    • Polska
                                    #3158
                                    t460s_orig_AS21_unpatched.bin is corrupted or does not contain a valid dump.
                                    There was an error... Aborting.​
                                    • ingus16
                                      • Apr 2024
                                      #3159
                                      Thanks for picking it up. An error was caused that identified the wrong chip before I thought it was W25Q125FW, WHICH IS 1.8V. I grabbed a vast magnifier glass, and it was W25Q125FV, which is 3.3 v. Lenovo Patcher is done its thing now.
                                      • XXS
                                        • Jan 2024
                                        Hello
                                        can anyone help me with SVP
                                        Lenovo P72 20MB (S/N PF-1FMMCY), Autopatcher will not work
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
