yes , so I have do it correctly but there is still bios password
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Attached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hello, I have been trying to unlock the Thinkpad x260 (supervisorpass) for some time now, I used Lennovo BIOS autopatcher and the laptop does not boot, I have tried a few other methods, unfortunately to no avail, svod4 also did not work (you may need to close the power lines with resistors), unfortunately I did not find a diagram for this, utb also failed. If someone would be so kind as to help me with this, I would be very grateful. Regards
thinkpad x260
MB - NM-A531 rev. 3.0 2015-11-2Attached FilesComment
thank you once again, I did as in the manual, of course everything went well, thank you for the quick and specific help, if I can help with anything I will definitely do it, I compared two bios, I think that next time I will be able to handle this model without any problems. Best regards and thank you again.Comment
Read this ...
https://www.badcaps.net/forum/troubl...79#post1850079Comment
X13 Yoga Gen 2 (Type 20W8, 20W9) Laptop (ThinkPad) - Type 20W9
ThinkPad X13 Yoga Gen 2
SN:PW-01LMB7
BIOS TYPE : GD25Q256C@SOP16
COMPLIANCE ID :TP00127A
TYPE: 20W9S0MG00
With some trial and error I was able to reliably patch BIOS dumps for SVP-locked Lenovo machines up to the 8th generation...
Read post 1, follow the "how to use the patch" instructions.
Also read the rules before posting
I have been trying to do this today and have gotten stuck. I have tried the python autopatcher but I get the following error
Using UEFIReplace to inject 2 DXE drivers...
[1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
.\Downloads\lenovo_autopatcher_0.2\lenovo_autopatcher\patch\lenovo-bios.bin is corrupted or does not contain a valid dump.
There was an error... Aborting.
The machine is:
Type: Lenovo L390
Serial R9-0V3RDP 19/05
Motherboard Model Model Number: I don't know where to find.
have added the bios dump in the attachments.
Many thanks.Comment
Hi, me again, I figured out the first issue which was I was reading off the wrong chip. Have read from the right one now. Taken a back up and patched it but it won't boot. I don't know how to comment on the previous post I made but here are the patched and non patched versions.
When booting the patched version I get a pieazo speaker tune and then no more boot happens. I have now flashed the backup back and got it working but supervisor password is back
thanks Vesko356
edit: adding patcher messages
[2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
Looking for volumes to patch...
[1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
Not found... Skipping.
Done.
PATCH FILE: lenovo-actual-bios_PATCHED.bin
Use the file below, follow the "how to use" instructions in post #1.
Consider a donation in support of the forum.
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Is there a way to retrieve the bios password from the chip? I haveover 30 machines with the same bios password and it would be too much time to do the patch on all 30. Otherwise these lenovos need to be scrapped and that would be a big shame!Comment
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by intelgHello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
Here is the hardware identification specs:
HP EliteDesk 800 G6 Desktop Mini PC
Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
BIOS ver S21 Ver. 02.05.01 01/05/2021
Born on date: 07/26/2021
SN MXL11841GN
SKU 3X8V9UCHABA
UUID 8116E79EF6FFE94DB0B98A3188270C5C
SYSTEM BOARD ID 8710
SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...-
by KenziHi everyone,
I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
- Loading...
