 ok so the CH341A will be of absolutely no use to me for reading/writing the EC
 And still, if I understand correctly, there is no alternative to using a Vertyanov adapter? or maybe here: https://www.badcaps.net/forum/showth...=111439&page=2 with an RT809H but for a single troubleshooting it's not cheap. Or is there another solution that I missed?Comment
 It would be great if you could use the ThinkPad maintenance utility to bypass the password and use eeprom init to clear the EEPROM if the super administrator password was setComment
 Could this application even allow you to delete the password even for my model? I have the impression that it only works via a USB boot first and I cannot change the boot order... precisely because I do not have access to the bios, even this option is blocked. I imagine it can't be run on Windows?Comment
 I don't know if you can help me by installing the patch on Lenovo L490 and the machine just beeps and doesn't show an image.Comment
 You must post the serial number.
 .Comment
 I just want to post to say thank you to @Knucklegrumble for this great tool. Thank you very much.
 My ThinkPad T470s 20HF was bricked after recent BIOS update through Think Vantage from Lenovo. I can only see the keyboard lights flash and hear the CPU fun spinning after the failure. The screen will not light up. This was fixed by reflashing the BIOS using a new bought CH341a programmer and BIOS bin file from this thread.
 But it only takes me to the Supervisor Password enter page for BIOS setting. I am sure that my Supervisor password is correct. However, the system prompts error. After a few times of tries, I found this magic tool. I used this tool to patch the BIOS file downloaded from this forum and it worked. The Supervisor password was cleared and I could use my laptop again finally.
 Hope this information helps.
 Thank you all for this wonderful forum.Comment
 Need help to remove bios pass lenovo x1carbon 8 TH Gen.
 Thx!
 Original dump attachedAttached FilesComment
 You must post the serial number.Read the updated rules.Havn`t you tried the Autopatcher ?
 .Comment
 Hello, i tried the autopatcher and i get no post (after patcher laptop power on, stay like that for 10 seconds then its start beeping, i followed all the instruction).You must post the serial number.Read the updated rules.Havn`t you tried the Autopatcher ?
 Sorry for asking without specifying what i tried, i dont have any ideea left except asking for help.Comment
 Read the post above yours, the Autopatcher works on the T480 .
 Please read the rules.
 .Comment
 Clean the ME firmware on your original bios,sometimes that works.Comment
 When the PC gets tired of playing, it no longer even asks for the password yet still writes yet still writes
 Don't ask me, I don't know what I did, a few random conditional jumpsAttached FilesComment
 HERE IS YOUR FILE PATCHED
 STEP 1: Flash given patch file (x1 carbon original_PATCHED)
 STEP 2: Boot the machine
 STEP 3: ENTER in to the BIOS settings
 STEP 4: Enter 1234 when asked for Supervisor Password
 STEP 5: Press enter when it shows Hardware ID
 STEP 6: Press space bar 2x when asked
 STEP 7: Turn off machine
 STEP 8: Write your original BIOS (x1 carbon original)
 STEP 9: Reset BIOS settings to factory defaultAttached FilesComment
 Please help me to patch bios for Lenovo P50s - after autopatcher 2.0 5 long beeps and black screenAttached FilesComment
 .Comment
 Supervisor pass removed, no need to use for any flash programming.
 Thanks for the help. I really appreciated all the knowledge shared in this forum and the persons here.
 All the best.
 APComment
 Hello
 does it work if i use dump patched from another computer on new computer ?
 for exemple, i dump old bios on an P71, patched it, worked well, can i use this patched file on another lenovo p71 ?Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
