    • 22206
    Originally posted by renanjan
    my dosent works... give me a sounded beep
    can i help?
    You MUST:
    Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      #2902
      Originally posted by RethoricalCheese
      Here's what I did. It's quite easy to modify. Not that it makes any difference to getting it to unlock
      -S (Initialize serialize information)
      -U (Initialize user information)
      -C (Initialize configuration information)
      RethoricalCheese your inbox is full
      -S -U -C none remove password, only Full init or modified utilities
      • meowmeow123
        • Nov 2023
        • PH
        #2903
        Originally posted by bivikoc825
        This is how I did it after I suspected TPM to be refusing to boot the laptop (screen didn't lit up at all with 5+5 short beeps, CPU fan spins and auto shutdown):
        1. Reflash to original BIOS from backup, of course in locked state. Validate the flash content if you can.
        2. Reattach everything.
        3. Boot into Windows(either from live USB image or transplant bootable drive from another system) and clear the TPM by using clear-tpm -useppi command from powershell. (Physical presence for clearing was enabled in my BIOS.) I'm not sure if the problem was exactly caused by TPM but I just did it just to be safe.
        4. Restart the laptop by holding shift when you click on [Restart] for complete power cycle and confirm to clear the TPM from BIOS prompt. The laptop will automatically reboot afterwards.
        5. Restart, enter BIOS and browse to [Config], enter [Power] and disable built-in battery. (My habit before disassembling any ThinkPad laptop.)
        6. Disassemble, disconnect internal battery and also CMOS battery.
        7. Flash patched BIOS. Use the premade one if you still fail. Validate the flash content if you can.
        8. Do not connect internal battery and CMOS battery, just put the bottom cover back.
        9. The laptop should automatically power up when you plug the power adapter in, with warning message i.e. time not set.
        10. Do not press other keys, don't care about the other options. All you need to do is press F1 to access BIOS. Follow the exact same steps to clear the password.
        This is from X250 and my experience will only apply on this model with the exact same symptom.
        How to flash bios bin file is there tool for that
        • Eddytech
          • Apr 2022
          • Nigeria
          #2904
          Greetings everyone, I've some Lenovo e570 with bios password, I tried rewriting bin but password remain, then I ,saw this thread on auto patcher, I've downloaded it and python also but the problem now is, I don't know how to lunch it using python
          • Eddytech
            • Apr 2022
            • Nigeria
            #2905
            Don't know how to use the autopatch,
            Lenovo E570 laptop
            Board number: CE570 NM - A831 REV:3.0
            Request: BIOS password Removal
              • 22206
              Lenovo E570 laptop
              https://www.badcaps.net/forum/showpo...postcount=2901
              • t34v2
                • Mar 2014
                • 25
                • poland
                #2907
                Hello.
                Could You help with password removal? I have Carbon X1 3rd.
                Mainboard :LMQ-2 MB.13268-1 448.01430.0011
                I have tried to patch my bios dump using autopatcher from post #1
                Result: 5 beeps twice , no display, turns off
                I have tried patched dump from these links:
                https://www.badcaps.net/forum/showthread.php?t=87588
                https://www.badcaps.net/forum/showpo...0&postcount=11
                EDIT:
                I made it working.
                Ive cleaned ME region in this file:
                Laptop booted up with checksum error and password prompt
                So i used autopatcher to patch it. BANG and it worked.
                Im attaching the file: x1_PATCHED.rar
                • fefo1993
                  • Nov 2023
                  • 8
                  • Italy
                  #2908
                  Hi guys, i have a Thinkpad x250 with locked bios asking supervisor password and no boot without inserting it.
                  I first dump the bios using CH341A + SOIC8 clip + CH341A Programmer v1.18, and than i used lenovo autopatcher v02 from the firts post to try to patch it.
                  But autopatcher give me the error " <file-name> is corrupted or does not contain a valid dump".
                  So i tried to take another x250 (that i bougth as replacements parts and NOT boot), dump bios, patch it, and the patched file was generated with no error!
                  At this point, i flashed this patched bios to the firts x250, but when i try to boot up it, power button flash 3 time and nothing happens. So, i tried to rewrite his original dump, but the laptop not boot anymore.
                  Now my x250 doesn't boot, black screen, and power button led flash 3 time..
                  any solution?
                  thanks a lot
                    • 22206
                    Post the laptop serial number - https://www.badcaps.net/forum/showthread.php?t=103570
                    Your backup is corrupt, the size is too small it should be MB not KB.
                    https://www.badcaps.net/forum/showpo...40&postcount=2
                    Originally posted by piernov
                    When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                    On Windows, you can use the command "fc /b" to check if two dumps are identical.
                    Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                    Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
                    • fefo1993
                      • Nov 2023
                      • 8
                      • Italy
                      #2910
                      hi, thanks for the reply..sorry, i forgot to write the serial number...it is PC-08A8JD
                      The zip file is a compressed zip, if you open you can see the bin file that is 16 MB size
                        • 22206
                        Read the text again "After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly."
                        Open your bios with a hex editor,i recommend HxD - https://mh-nexus.de/en/hxd/ ,your dump is all FF FF FF FF ,16MB of FF`s ,there is no other code. Open the X250 pre-patched bios in this thread and look at the code,your backup should be similar -> https://www.badcaps.net/forum/showthread.php?t=81573 . Its important to always make a good backup.
                        • fefo1993
                          • Nov 2023
                          • 8
                          • Italy
                          #2912
                          i solved by myself the problem!
                          I flashed this bios (using AsProgrammer 2.0.4) for x250 founded on this forum (HERE the original thread), and the device turn on again, but always locked with supervisor password.
                          Then, i patched the bios with autopatcher, and boom! supervisor password removed!
                          i reflash back the bios and restored it to default settings...
                          i attach the "stock" and the "patched" bios, so if someone need it can download and use it!
                          thanks a lot for the support, next time i will check if backuped bios will be corrupted or not before flash the new one
                          • Pusher
                            • Nov 2023
                            will this patcher work to remove the Supervisor Password with
                            Lenovo P16 Gen1 (Type 21D7)
                            Serial: PF4L989J
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1356
                              • France
                              #2914
                              Serial: PF4L989J
                              you have already posted here, no simple solution for this model
                              I don't think so
                              https://www.badcaps.net/forum/showthread.php?t=125661
                              • wuyaping
                                • Jun 2022
                                • 20
                                • china
                                #2915
                                Can you upload your picture again? It looks very blurry
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1356
                                  • France
                                  #2916
                                  There are still things to do to finish
                                  • diappollo
                                    • Nov 2023
                                    • 5
                                    • france
                                    #2917
                                    First of all, congratulations for this gold mine of information for anyone who wants to work on the bios of their machine!
                                    This is what leads me to ask for your help, like many I am looking to delete the supervisor password for one:
                                    -Thinkpad E15 GEN2
                                    - Model type: 20T9SOYE00
                                    Case (maybe special), I've had the PC for a while and for some reason, it asks me for the password at startup randomly? Random which turns into systematic...
                                    I read carefully: https://www.badcaps.net/forum/showpo...postcount=2901
                                    in particular sections 1 and 3.7.
                                    I purchased a CH341A, not ideal, I understood well but given my level of computing I limited the expense given the little chance of success that I put in it (I'm wrong you say?).
                                    1st Question: I can't locate the bios chip... can anyone help me?
                                    2nd: since the computer sometimes runs under Windows, are there procedures similar to the one presented at the beginning of the post to read/save/correct/dump the bios but under Windows environment ?
                                    Thank you in advance for your help, as it is strongly recommended to do, I will use the "search" function again but a lot of reading without much progress for the moment!
                                    • diappollo
                                      • Nov 2023
                                      • 5
                                      • france
                                      #2918
                                      Oops, unfortunately I didn't read the beginning of the post correctly, I have the answer to question 2.
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1356
                                        • France
                                        #2919
                                        "3:I read carefully: https://www.badcaps.net/forum/showpost.php?p=1285680&postcount=2901"
                                        4:it asks me for the password at startup randomly
                                        1: not stock in bios, look : https://www.badcaps.net/forum/showth...light=E15+GEN2
                                        2: Not possible
                                        3: Provide serial number
                                        4: Password at unattended boot
                                        • diappollo
                                          • Nov 2023
                                          • 5
                                          • france
                                          #2920
                                          Wow ! thank you for this quick feedback and (the anticipation of the questions)
                                          Sérial number : PF-2T7VT2
                                          so if I understood correctly, it doesn't happen at the bios level but at the "EC" level... what is that? I read the post carefully and I didn't see where the chip in question was located
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
