try this file and follow steps described in #1
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
[ NOTES ]
When booting the patched BIOS you might have to:
- Hold the anti-tamper switch down the whole time (use tape)
- Remove the hard disk or replace it with a locked oneAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
[ NOTES ]
Worked for me!
Thank you Knucklegrumble, I just followed EXACTLY what you described and fixed my poor Lenovo P51.
For the community reference I used a CH341A with NeoProgrammer 2.1.0.19, and a IC clamp (didn't remove the IC from the board as recommended in some articles).
MakComment
[ NOTES ]
My laptop now is not posting at all
Just power led with blank screen
I don't know what happened
Tried to reflash the bios the same result
Even tried the original bios file which was created before it didn't work.
Can the bios chip burned out?
Is it possible?
It is still accepting flash and the programmer still detecting the chip.
Any idea or suggestions? Plz ….Comment
Thanks for your efforts
Is it possible?
Any idea or suggestions? Plz ….----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Check if you didn't remove any component around bios chip by mistake while soldering/desoldering bios chip. Leave laptop on for a long time, from my experience it take between 1 to 2 mins to apply new settings from bios, you'll see keyboard leds flashing few times. I removed SVP from E490 with same method I created your patched bios, it should work.
I used the clip with ch341a programmer.
I believe if the chip burned it will not accept programming or even the programmer detect the chip.
It is accepting the flash and verify it successfully with no issue.
Anyway i will check the area around the chip as you said. And will update you back.
Thanks broComment
I recorded the bios of the laptop, there is no image, and it beeps 5 timesComment
I didn’t desolder the chip
Thanks bro
I see that your laptop can use both chipsets, try change it with W25Q128 if you have MX25L128
Also I gave up using clips because it can damage components placed near bios chipset and always desolder bios chipsets, there are some "pogo pins" i saw some users here use it and it's better than clips.Last edited by volinakis; 03-15-2023, 02:57 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[ NOTES ]
Appreciated
will try it after replacing the chipComment
Hello, can someone help me remove the password of my Lenovo X270 ?
Thank you very much !Attached FilesComment
patcher works fine for me
T460s
Python 3.11
Programmer 341a mini black
Softw : CH341a Programmer 2.2.0.10
thanks to @KnucklegrumbleComment
Hi, just wanted to say big thanks for the script and guide.
I succesfully managed to remove the Supervisor BIOS password on my T480.
For future reference, my machine is T480, type 20L6-SD8Q0M, June 2019, BIOS version 1.24.
Keep in mind you need to desolder the U49 chip (W25Q128JVS), it's located roughly between the RAM slot and where the discrete GPU would be. At first I made a mistake and desoldered U15 (near the CMOS battery) and was wondering why the patcher wouldn't work hehe.
I used RaspberryPi 4B and flashrom to read and write the binaries, but ran the patcher script on my Win 10 laptop.
Anyway, thanks again!Comment
Hi everyone
i have a Thinkpad yoga 15 typ 20DQS00A00 with SVP
Chip Winbond W25Q64FVS
this is a verified backup i would like to patch itAttached FilesComment
by macabookHello everyone,
Yesterday, 02:17 PM -
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
