hp 6050A2728501-MB-A01 bios
  • KillMe3
    • Jan 2023
    • 12
    Re: hp 6050A2728501-MB-A01 bios
    Hello everybody,
    i have a HP 850 G3 with bricked Bios
    is it possible to flash a new Bios with a programmer?
    The Chips are a WINBOND 25Q128FVPQ and 25Q64FVIQ
    do you need other Infomation?
    • peste
      • Dec 2016
      • 12742
      • ROMANIA
      Originally posted by KillMe3
      Hello everybody,
      it is... post the full name and model and the original bios..
      • KillMe3
        • Jan 2023
        • 12
        HP EliteBook 850 G3
        ProID L3D24AV
        • hardware1
          • Sep 2021
          • 2930
          • N/A
          HP EliteBook 850 G3
          ProID L3D24AV
          Your Backup not good, try to read this chip again (W25Q128FV).
          all donations are welcome,
          • KillMe3
            • Jan 2023
            • 12
            yes i think the BIOS is corrupted
            here the next try...
            • KillMe3
              • Jan 2023
              • 12
              no one who can help?
              is it possible to write the dump of another BIOS of the same Model of Notebook?
              • hardware1
                • Sep 2021
                • 2930
                • N/A
                #27
                Still the same, your file should contains Flash Descriptor Region. Which programmer you use, and are you using a clip?
                • KillMe3
                  • Jan 2023
                  • 12
                  its an XGecuT48 Programmer with an WSON8 to SOIC8 Adapter
                  • KillMe3
                    • Jan 2023
                    • 12
                    • KillMe3
                      • Jan 2023
                      • 12
                      Hp 850 g3 6050a2728501-mb-a01 bios
                      Hello everybody,
                      i have a HP EliteBook 850 G3 ProID L3D24AV with bricked BIOS
                      is it possible to flash a new BIOS with a programmer?
                      The Dumps are included.
                      Thanks and best Regards
                      KillMe3
                      • KillMe3
                        • Jan 2023
                        • 12
                        plz help!!!
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11706
                          #32
                          plz help!!!
                          HP EliteBook 850 G3 Base Model Notebook PC
                          • KillMe3
                            • Jan 2023
                            • 12
                            thank you... will test it later and respone
                            • KillMe3
                              • Jan 2023
                              • 12
                              dont work
                              the Power LED is blinking yellow and white
                              the shift Button ist blinking too
                              • KillMe3
                                • Jan 2023
                                • 12
                                plz help
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11706
                                  #36
                                  plz help
                                  Try again
                                  • Abir Emdad
                                    • Feb 2018
                                    • 12
                                    • Bangladesh
                                    #37
                                    Re: hp bios
                                    Originally posted by lapfix
                                    Try and give Feedback
                                    thanks dude, 100% working....
                                    • dennis akumu
                                      • Mar 2018
                                      • 104
                                      • kenya
                                      #38
                                      I have a hp 840 g3 with no display need a clear me file please
                                      board no: 6050a2728501-mb-a01
                                      attached are the original files.plizzz help
                                      • hardware1
                                        • Sep 2021
                                        • 2930
                                        • N/A
                                        #39
                                        Try this New BIOS with your 16MB Chip and put your 8MB Chip back.
                                        Serial Number: 5CG6293CQR.
                                        • adiasterix81
                                          • Aug 2017
                                          • 36
                                          • Romania
                                          #40
                                          can someone help me remove the password from this bios?
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • MDSI
                                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                            by MDSI
                                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                            Details:
                                            Model : HP OMEN 17-an012nf
                                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                                            Serial Number (S/N) : 5CD7280D51
                                            BIOS chip : Winbond W25Q64VSIQ
                                            Programmer : EZP2023+
                                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                            I already...
                                            07-28-2025, 07:11 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
                                          • DynaxSC
                                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                            by DynaxSC
                                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                            11-06-2022, 05:22 PM
