hp 6050A2728501-MB-A01 bios
  • KillMe3
    • Jan 2023
    • 12
    Re: hp 6050A2728501-MB-A01 bios
    Hello everybody,
    i have a HP 850 G3 with bricked Bios
    is it possible to flash a new Bios with a programmer?
    The Chips are a WINBOND 25Q128FVPQ and 25Q64FVIQ
    do you need other Infomation?
    • peste
      • Dec 2016
      • 13335
      • ROMANIA
      Originally posted by KillMe3
      Hello everybody,
      it is... post the full name and model and the original bios..
      • KillMe3
        • Jan 2023
        • 12
        HP EliteBook 850 G3
        ProID L3D24AV
        • hardware1
          • Sep 2021
          • 2945
          • N/A
          HP EliteBook 850 G3
          ProID L3D24AV
          Your Backup not good, try to read this chip again (W25Q128FV).
          all donations are welcome,
          • KillMe3
            • Jan 2023
            • 12
            yes i think the BIOS is corrupted
            here the next try...
            • KillMe3
              • Jan 2023
              • 12
              no one who can help?
              is it possible to write the dump of another BIOS of the same Model of Notebook?
              • hardware1
                • Sep 2021
                • 2945
                • N/A
                #27
                Still the same, your file should contains Flash Descriptor Region. Which programmer you use, and are you using a clip?
                • KillMe3
                  • Jan 2023
                  • 12
                  its an XGecuT48 Programmer with an WSON8 to SOIC8 Adapter
                  • KillMe3
                    • Jan 2023
                    • 12
                    • KillMe3
                      • Jan 2023
                      • 12
                      Hp 850 g3 6050a2728501-mb-a01 bios
                      Hello everybody,
                      i have a HP EliteBook 850 G3 ProID L3D24AV with bricked BIOS
                      is it possible to flash a new BIOS with a programmer?
                      The Dumps are included.
                      Thanks and best Regards
                      KillMe3
                      • KillMe3
                        • Jan 2023
                        • 12
                        plz help!!!
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12237
                          #32
                          plz help!!!
                          HP EliteBook 850 G3 Base Model Notebook PC
                          • KillMe3
                            • Jan 2023
                            • 12
                            thank you... will test it later and respone
                            • KillMe3
                              • Jan 2023
                              • 12
                              dont work
                              the Power LED is blinking yellow and white
                              the shift Button ist blinking too
                              • KillMe3
                                • Jan 2023
                                • 12
                                plz help
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12237
                                  #36
                                  plz help
                                  Try again
                                  • Abir Emdad
                                    • Feb 2018
                                    • 12
                                    • Bangladesh
                                    #37
                                    Re: hp bios
                                    Originally posted by lapfix
                                    Try and give Feedback
                                    thanks dude, 100% working....
                                    • dennis akumu
                                      • Mar 2018
                                      • 112
                                      • kenya
                                      #38
                                      I have a hp 840 g3 with no display need a clear me file please
                                      board no: 6050a2728501-mb-a01
                                      attached are the original files.plizzz help
                                      • hardware1
                                        • Sep 2021
                                        • 2945
                                        • N/A
                                        #39
                                        Try this New BIOS with your 16MB Chip and put your 8MB Chip back.
                                        Serial Number: 5CG6293CQR.
                                        • adiasterix81
                                          • Aug 2017
                                          • 40
                                          • Romania
                                          #40
                                          can someone help me remove the password from this bios?
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
