Asus UX51VZ Zenbook U500V - BIOS
  • soslaptop
    • Mar 2014
    • algeria
    I need bios mains please
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: Asus UX51VZ Zenbook U500V
    try this and confirm,,
    dont forget to backup your old bios, and post here...
    goodluck
    • lakrouf
      • May 2015
      • 12
      • 84316327138
      this dump bios is not worcking
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        post your old bios here...
        • cacla
          • Apr 2015
          • 444
          Here working dump
          • Flyview
            Flashing ASUS UX51VZ with correct bios
            by Flyview
            Hi!
            Happy to be part of this forum for my first post!
            Short story:
            I believe my dad's UX51VZ has an incorrect bios (v207) for a UX51VZH flashed onto it. I'm not quite sure what the differences are between UX51VZ, UX51VZA, and UX51VZH. The serial number of this machine is D5N0CY845932229 and comes up as a "UX51VZ-DB103P" when checked on this ASUS website. All of the bioses can be found at this ASUS website.
            1) Do I have the correct bios or should it be the v205 for UX51VZ? Is there something I can check inside the machine to make sure?
            03-31-2024, 11:56 PM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
