Lenovo S5 bios needed
  • Mrrbonti
    • Apr 2020
    • 29
    • Ghana
    please i need bios for lenovo S5 2nd Gen (Type 20JA) BIOS (ThinkPad) CIMS1 LA-D214P Rev 1.0. powers on NO display
  • peste
    • Dec 2016
    • 13920
    • ROMANIA
    Re: Lenovo S5 bios needed
    post the original bios here..
    • Mrrbonti
      • Apr 2020
      • 29
      • Ghana
      original dump
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        Originally posted by Mrrbonti
        original dump
        Try and feed back
        • Mrrbonti
          • Apr 2020
          • 29
          • Ghana
          Originally posted by lapfix
          Try and feed back
          powers on but NO display
            • 22276
            Try this bios .
            • Mrrbonti
              • Apr 2020
              • 29
              • Ghana
              Originally posted by SMDFlea
              Try this bios .
              works perfectly.thanks a lot
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                Great SMDFlea , can you please explain how you choose another ME version !
                About this case it's : 11.6.1.1142 and that's what i choose too , and it didn't work ( no display)
                Your version is : 11.8.77.3664 !!! i can't understand this specific update chhosing.
                Thank you
                  • 22276
                  Thank you
                  I merged the bios update and updated to newer ME firmware from the lenovo support page https://pcsupport.lenovo.com/gb/en/p...t?name=Chipset
                  I always use FIT flash image toolkit ,never crap like MeInject or easycleanme or whatever its called ,and i always follow the ME cleaning guide at win-raid. Cleaning the ME manually has a much higher success rate.
                  https://winraid.level1techs.com/t/gu...lization/31277
                  • lapfix
                    • Mar 2020
                    • 2764
                    • my workshop
                    You are great ,thank you
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • to5it0
                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                      by to5it0
                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                      I have opened the laptop and identified the main BIOS chip...
                      10-24-2025, 01:35 AM
                    • Joluvillas
                      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                      by Joluvillas
                      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                      06-18-2024, 10:35 PM
                    • 1g0r
                      Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                      by 1g0r
                      First, the data in brief:
                      Manufacturer: Lenovo
                      Model: ThinkPad L15 G3 21C3-0016GE
                      motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                      IC Bios 1: MX77L25650F
                      IC Bios 2​: MX25L25673G
                      EC Chip: NPCX997KAABX
                      So far I've been a silent reader, but now I need your help
                      I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                      I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                      The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                      01-18-2025, 02:39 AM
                    • akwky
                      by akwky
                      Hi!
                      04-14-2025, 01:56 PM
