Need bios dump HP 14-ck or HP 240 G7
  • Dstecno
    • Jun 2019
    • 30
    • México
    Hello guys, i have an HP 240 G7 laptop with bios problem, it start and says bios is corrupted, but can be restored by itself, there is not bios files for this model in the HP web site, somebody in this forum have the bios dump? the board is:
    GRANGER-6050A2977701-MB-A01 (A1)
    usually in the HP 14-ck1000 and HP 240 G7
    thank you guys
  • Dstecno
    • Jun 2019
    • 30
    • México
    Re: Need bios dump HP 14-ck or HP 240 G7
    sorry friends, i did make a mistake, the rigth MoBo model is GRANGER-6050A2977701-MB-A03 (A3)
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Better is to post your old dump , someone gonna fix it for you.
      • Carlos ivan
        • Aug 2019
        • Perú
        bios please
        • sikocan
          • Oct 2019
          • 347
          Tried this on HP 14-ck0055tu - not even power light comes on at charger.
            • 22279
            Did you check your bios BID ,do you need 0849E or 08498
            • akorede
              ENGINEER
              • Nov 2020
              • 16
              • nigeria
              bios file needed pls
              thanks in advance
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                by haitham sharabati
                Hello engineers 😀,
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                💀 Problem:😅
                08-07-2025, 04:54 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
