clear me bios for this board
Macbook Air 820-00165 BIOS
Re: Macbook Air 820-00165-A schemati and boardview
Thanks highpulse
I'll try next time so
What is clear me ? Never used one..
What is it for ?
Thanks -
@highpulse is it possible to remove EFI lock in 2013 MBP by reflashing BIOS??? THanx...Comment
Hi
A clean me region will not remove efi password...If you have a dump with a efi password upload it and i will remove it and i will tell you whats needed to be done next so the cloud don't reset it again. The other way to remove a efi password is with a donor bios so let say it a 8mb file the top have 4mb is merged with the bottom half of the donor and all you need to do after is replace the serial to match the original. I have a way to do it with out touching the original file i just remove password .
Techman1025Comment
so... will send u the original dump file.... waitComment
@techman1025 so... will send u the original dump file.... wait can i use regular TL866CS programmer to backup the original dump??? thanks...Comment
Hi
I use the TL866A with the correct adapter .
Techman1025Comment
and here it is... @techman1025 my dump... couldnt find right adapter and had to jumper pins to get dumpAttached FilesComment
Hi ok Password removed butyou need to follow these steps nexted to complete the process and you will be total good no need to do anything else.
Make sure to do this steps after reflash: Unpack zip
Resetting NVRAM
i) Shut down your Apple Mac.
ii) Locate the following keys on the keyboard: Command, Option, P, and R.
iii) Turn on your Mac.
iv) Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
v) Hold these keys until the computer restarts and you hear the startup sound for a second time.
vi) Release the keys.
And after that... reinstall the OS!
Techman1025Attached FilesComment
ok file cleaned..follow step after you reflash....if not the cloud will reset it.
Resetting NVRAM
And after that... reinstall the OS!Attached FilesComment
Hi ok all cleaned ...you need to follow these steps NEXT so the cloud won't reset it self .
Steps after clearing P/W
1. Shut down your Mac.
2. Locate the following keys on the keyboard: Command (⌘), Option, P, and R.
3. Turn on your Mac.
4. Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
5. Hold these keys until the computer restarts and you hear the startup sound for a second time.
6. Release the keys.
nexted do clean install on OS
techman1025Attached FilesComment
techman, can you help me to remove the password from this dump?Attached FilesComment
I have a MBAir 4,1 which is EFI locked... is it possible to get a help here?Comment
Sorry for the late reply follow these steps now and you won't have any problem bios is clean now.Make sure to do this steps after reflash:
Resetting NVRAM
Hello, I forgot my efi password. Programmed Your file. Your dump I inadvertently deleted. Now I don't know what to do. Can't install mac os. Hangs on loading.Sorry for the late reply follow these steps now and you won't have any problem bios is clean now.Make sure to do this steps after reflash:
Resetting NVRAM
What to do?Comment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
