Lenovo ThinkPad T470 bios password decrypt
  • wiltd
    replied
    Re: Lenovo ThinkPad T470 bios password decrypt
    frphpaz, I don't know what I'm doing yet with the BIOS unlocking, but the guide says after you flash the patched rom/bin and remove the password you need to flash your original rom/bin back on. Did you do that?
    Also, a drive won't show up if your laptop BIOS drive setting is set to use intel rapid storage technology (IRST)/optane you can't boot a generic windows build from microsoft without adding the IRST drivers to the boot and image wim files. Easiest to change to AHCI for your drive in the BIOS and try again. Or get an OS image from the original manufacturer if they offer it.
  • wiltd
    replied
    Thank you Markus1741 for pointing me in the correct direction. I followed those instructions for the autopatcher, his script needed some chmod'in and an alias in bashrc to make python in his scripts run as python3 but then I got it to spit out my file. A diff on my file to yours show a match! Thank you for helping me learn how to do this!
    Next time my kid's home from college with that laptop we'll follow the rest of the steps and hopefully it goes well I'll try to remember to report on it then.
  • frphpaz
    replied
    Hello wonderful group, I need your wise advice, to start, thanks to you, I have finally managed to remove the administrator lock from my Lenovo T470 and it now allows me to modify the bios, now my problem is that when I connect the SSD m2 PCI NVME hard drive immediately The password lock appears, but when I turn on the PC without said hard drive there, it does let me enter the bios or execute USB boot, when I do the process to install the operating system, it does not recognize the hard drive, is there a way I can format and thus be able to install the operating system?
    In an improvised way, using a mechanical external hard drive, I was able to install the operating system but only with that external hard drive installed. I would like your advice so I can use it in the normal way. I thank you very much for your attention and I hope for your help and suggestions to try to to be able to use my computer correctly.
  • Markus1741
    replied
    Originally posted by wiltd
    My son bought a T470 on ebay and it came Supervisor password locked in the bios. I pulled the bios and attached it, but I am totally lost on how to remove the password. Does anybody have the ability to fix the bios for me or step me like a newb through the process please?
    Thanks!
    Read this page ...
    https://www.badcaps.net/forum/showpo...52&postcount=1
    Or this YouTube video ...
    https://www.youtube.com/watch?v=1ypCYSxbxyY
  • Vesko356
    replied
    Thanks!
    Read post #125 and the rules
  • wiltd
    replied
    Thanks!
    replied
    Originally posted by badola
    plsss remove password t470
    Read this,you can unlock it yourself - https://www.badcaps.net/forum/showthread.php?t=103570
  • badola
    replied
  • ecolaptop
    replied
    Originally posted by ecolaptop
    Hi. Thank you in advance.
    I have 2 t470 identical once.
    Both have supervisor password and now I cant set date and time etc.
    One I was able to patch it with Lenovo patcher the other one
    when bios file patched gets stuck on Lenovo start-up screen - give no output to keyboard internal or external and I can't do anything but when reflashes with original bios it starts to work like normal - still with password as i could not execute the patched bios.
    I even tryed to load patched bios file from the one I succeeded with but still same behaviour.
    Could anyone explain this to me and / or just remove the SP from attached dump please?
    I really appreciate your time and effort in it - I'm just to stupid do manage on my own so have MERCY!
    Thank you once again.
    My best regards
    OK so I'm stupid and I completely forgot the fact that to get in you need to press F1 as it boots up lolol. It is not like I do this first time but for some reason I just left it without pressing awaiting post screen lol. I'm stupid - good that nobody replied that would be awkward lol.
    This worked 2nd time now so I thank you once again.
  • ecolaptop
    replied
    My best regards
  • kordex35
    replied
    Re: Plz i need to clear bios password for lenovo thinkpad T470
    Originally posted by narsil
    Plz i need to clear bios password for lenovo thinkpad T470...thanks
    ok
  • ploggy
    replied
    Originally posted by Vesko356
    Read the rules before posting:
    You must attach files directly to your post instead of linking to external websites.
    Apologies. I would remove the link but I cant edit the post for some reason ?
  • Vesko356
    replied
    Originally posted by ploggy
    Here is the bios dump
    https://*****/t-93***O8cH
  • ploggy
    replied
    All good! once I figured out that the tamper switch needed to be untaped everything else fell into place, laptop back to fully functional condition! thanks everyone for the great work you do
  • ploggy
    replied
    Hi all
    I have dumped my t470 Bios file multiple times with a CH341A using both Colibri and ASProgrammer tool but none of the dumps CRC's seem to match?
    I made sure to disconnect both batteries plus the cmos battery and I've taped the tamper switch down also.
    I can post one of the dumps if you want but I'm afraid they wont be vaild dumps?
    Is it possible to derive the password just from a dump?
    EDIT: Looks like I can get matching dumps if I remove the tape from the tamper switch :P
    replied
    Originally posted by chandrakant
    PLZ Lenovo T470 Patch File PLZZZZZZZZZZZ
    See post #101 and -> https://www.badcaps.net/forum/showthread.php?t=103570
  • chandrakant
    replied
  • Ole82
    replied
    Thanks A LOT!
    Everything Working Great!
  • Markus1741
    replied
    Originally posted by Ole82
    Good day everyone and to the Bios unlocking knowing peoples.
    I have want to asking for help with my T470 bios.
    I have bios password on it.
    Please help me to clear it.
    Here is the dump:
    Try ...
  • hoaca388
    replied
    F1 to setting, set all security options to default.
  • RMDUiFT
    Should I buy a Lenovo Thinkpad E495 with bios password?
    by RMDUiFT
    Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
    I have a few questions:
    • If I would buy this laptop and have
    08-25-2024, 09:00 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • tlindi
    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
    by tlindi
    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
    Ack
    Ack
    01-30-2025, 04:26 AM
  • Nopslide
    by Nopslide
    04-01-2024, 04:27 PM
