Panasonic CF-19RDRAHHD password
  • noname512
    • Oct 2018
    • 41
    • United Kingdom
    Re: Panasonic CF-19RDRAHHD password
    Originally posted by SMDFlea
    Another to try .
    Dont work
    • Motherboard Repairs
      • May 2019
      • 63
      • United Kingdom
      Originally posted by noname512
      Dont work, laptop on and asking pass
      Try these files 1 by 1 if it don't work then i give up
      • noname512
        • Oct 2018
        • 41
        • United Kingdom
        Tested 1 , only 1 green light on when connecting power but when switching on the laptop wont power on anymore staying with the same green led on and do nothing,
        Tested 2 , same as test1 , the chip is still ok , programer autodectecting ic, to be sure that chip is soldered good i used solder iron, testing 3
        Tested 3, found that when connecting power cord the light on , keep pressing power button the light goes off , so i put the chip off and connected power cord and its the some result, green light on = power on but no image , the laptop do nothing, testing 4
        Tested 4, some as 1,2,3 . Laptop power on when the power cord plugged but no image, when pressing power button for 4 seconds the green light goes off.
          • May 2019
          • 63
          • United Kingdom
          Tested 1 , only 1 green light on when connecting power but when switching on the laptop wont power on anymore staying with the same green led on and do nothing, testing 2
          give it 1 min wait if nothing proceed with other files
          • spbios
            • Dec 2015
            • 16
            • morocco
            please unlock bios password
            CF-19RDRAHHD
            1JKCA88799
            check this and let me know...
              • May 2019
              • 63
              • United Kingdom
              #26
              update if spbios file work as i have just given up if this file fail i will try last attempt
              • noname512
                • Oct 2018
                • 41
                • United Kingdom
                #27
                Now flashing spbios patched
                Tested laptop on , and asking for password
                • spbios
                  • Dec 2015
                  • 16
                  • morocco
                  #28
                  which mk ver?
                  • noname512
                    • Oct 2018
                    • 41
                    • United Kingdom
                    #29
                    which mk ver?
                    mk4
                      • May 2019
                      • 63
                      • United Kingdom
                      #30
                      mk4
                      Try this one
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        #31
                        Also try my file..
                        • noname512
                          • Oct 2018
                          • 41
                          • United Kingdom
                          #32
                          Try this one
                          Tryed unlocked - Laptop on but asking for password
                          Programming NEW FILE
                            • May 2019
                            • 63
                            • United Kingdom
                            #33
                            I have thought of everything if something pops i will post, but it will be unlikely best bet is to find a dump unless some cracks it
                            • spbios
                              • Dec 2015
                              • 16
                              • morocco
                              #34
                              try this one!
                              • spbios
                                • Dec 2015
                                • 16
                                • morocco
                                #35
                                check if u get HDD password instead...better to remove hdd/ssd first and reflash
                                • noname512
                                  • Oct 2018
                                  • 41
                                  • United Kingdom
                                  #36
                                  Originally posted by imranromi
                                  Also try my file..
                                  This works, the first power on was in about 10-15 seconds with screen off then it power on normally.
                                  Thank you so much everyone!
                                  • noname512
                                    • Oct 2018
                                    • 41
                                    • United Kingdom
                                    #37
                                    try this one!
                                    Every try was without hdd/ssd
                                    Now checking this as well
                                    • spbios
                                      • Dec 2015
                                      • 16
                                      • morocco
                                      #38
                                      did u tried my dump?
                                      • noname512
                                        • Oct 2018
                                        • 41
                                        • United Kingdom
                                        #39
                                        Just tried your dump Panasonic CF-19 MK4._clean.zip. This work too, no more password! Thank you !
                                        • spbios
                                          • Dec 2015
                                          • 16
                                          • morocco
                                          #40
                                          good!
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
