bios for hp probook 430 g1
  • THESMAGD COMPUTER
    • May 2018
    • 4
    • kenya
    helo guys i need bios for hp probook 430 g1
  • Sebas3124
    • Mar 2014
    • 15
    • Colombia
    Re: bios for hp probook 430 g1
    • ads
      • 6
      • Lithuania
      Hello colleagues I have HP Probook 430 G1 12239-1 48.4YV09.011. I flashed Sebas3124 dump, but every time laptop turns on, need wait 15s to get HP post screen. Newest BIOS update was done from HP site, still same. Default set, same. Can it be that this dump is not for my MB? There are any differences with 12239-1 48.4YV09.011 and 12239-1N 48.4YV09.01N dump? Thanks
        • 21679
        The ME firmware needs cleaning .Post your original bios backup if you have it .
        • ads
          • 6
          • Lithuania
          I have, but with this DUMP caps lock was blinking two times, which means that its demaged, Any posibility now to fix already flashed dump? Or what is needed to clean ME? Thanks
          • lapfix
            • Mar 2020
            • 2756
            • my workshop
            try and give deedback
            • ads
              • 6
              • Lithuania
              No, with that one laptop not working, now fast blinking charger light. I adding now working dump, which have ME problems, 15s to load. Can anybody fix it? Thanks
              • ads
                • 6
                • Lithuania
                I found another clear ME dump on internet, but there I have "warning machine is not in committed state" error everytime ... Still searching how to fix it...
                • peste
                  • Dec 2016
                  • 13434
                  • ROMANIA
                  try..
                  • ads
                    • 6
                    • Lithuania
                    Thank you colegues, i solved it by myself with clear me for that one with 15s delay dump. I adding my final working dump with nevest BIOS version, maybe for somebody it will be needed. Thanks again colegues
                    • Gudguy
                      • Jun 2016
                      • 48
                      • Nigeria
                      Hi friends i need help in rebuilding this hp 430 g1 bios bin.here attached the bios bin
                      • peste
                        • Dec 2016
                        • 13434
                        • ROMANIA
                        try..
                        • Gudguy
                          • Jun 2016
                          • 48
                          • Nigeria
                          thanks my friend,you are the best
                          • Gudguy
                            • Jun 2016
                            • 48
                            • Nigeria
                            the bios didn't work.
                            • lapfix
                              • Mar 2020
                              • 2756
                              • my workshop
                              Try
                              • Gudguy
                                • Jun 2016
                                • 48
                                • Nigeria
                                Originally posted by lapfix
                                Try
                                The laptop still not powering up only showing fast blinking light on the charger port.seems the bios bin is damaged.have used another bios bin from another site which power up the laptop but not display.here attached the working bios from other site. i need help .
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12271
                                  Here
                                  • Gudguy
                                    • Jun 2016
                                    • 48
                                    • Nigeria
                                    Originally posted by hoaca388
                                    Here
                                    Thanks will give feedback
                                    • Gudguy
                                      • Jun 2016
                                      • 48
                                      • Nigeria
                                      Here
                                      wow, it work like a charm.thanks
                                      • Ismail Siraje Ittembe
                                        Kampala Member
                                        • Jan 2024
                                        • 25
                                        • Uganda
                                        HP Probook 430 G1
                                        serial:2CE4101DBW
                                        product: G2R55UP#ACF
                                        need help it turns on only the power button lights but nothing goes through
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
