BIOS file for HP Compaq 615
  • panoss
    • Mar 2014
    • 35
    • Greece
    Hi guys.
    I have one (in fact two) old laptop, a Compaq 615.
    When I press the button the fan spins, looks like the mobo is booting but the scrren remains blank. Caps lock blinking.
    From what I read it most probably is the BIOS, so I downloaded the 3 files from HP:
    1. HPQFlash for HP Notebook System BIOS (68GVV) - F.20 Dec 12, 2011
    2. ROM Image for HP Notebook System BIOS (68GVV) Remote ROM Flash F.0C 2.2 MB Nov 23, 2009
    3.ROMPaq for HP Notebook System BIOS (68GVV) – FreeDOS Bootable Media
    (they are exe files, unzip them to see all the files)
    But, which is the file that I must upload to the EEPROM ic?
    I suppose it must be one of the files contained in one of the zip files.
    I want to flash it with a CH341A programmer.
    sp46875.exe contains files:
    -HPQFlash.exe 1.336 KB
    -ROM.CAB 1.455 KB
    -sp46875.cva 2KB
    -WSSP46875.rtf 2 KB
    sp55877.exe contains files:
    -HPQFlash.exe 4.188 KB
    -ROM.CAB 1.459 KB
    -WSSP55877.rtf 33 KB
    ROM.CAB contains:
    -efibios.sig 1KB
    -Rom.bin 2.048 KB
    -Rom.sig 1KB
    ver.sig 1KB
    ver.txt 1KB
    It 's the 'Rom.bin'?
  • peste
    • Dec 2016
    • 13451
    • ROMANIA
    Re: BIOS file for HP Compaq 615
    Are you sure the bios is the problem? Before reading or writing, the bios chip should be removed from the motherboard, do not use the clip you will have errors, solder the chip on the programmer if you do not have an adapter. Make a copy before and ...
    Try this
    • panoss
      • Mar 2014
      • 35
      • Greece
      I don't know if the bios is the problem, just from what I read in similar topics on the internet, it's very probable.
      If it's not the bios then I guess something 's wrong with the graphics chip.
      (I connected it to an external screen through VGA output but nothing, so I suppose the screen is not the problem)
      I will do as you suggested peste, thank you!
      • panoss
        • Mar 2014
        • 35
        • Greece
        I flashed it.
        At first I tried your archive peste, bur it was taking too long.
        I waited for half an hour and it still was writing....
        I thought something 's wrong, so I tried with the file I had downloaded from hp 's site.
        It also took a loooong time, but I thought maybe I should let it a bit more.
        It took almost one hour!!!
        I used flashrom in puppy linux live usb.
        One hour!
        I reassembled everything, but it stil does the same, so I guess it was not the bios...
        I 'm thinking of reworking the graphics chip with a heatgun, but I 'm not sure which is the graphics chip. And I can't find any photo pointing it.
        • peste
          • Dec 2016
          • 13451
          • ROMANIA
          it takes a few minutes to write the bios chip ...
          https://www.youtube.com/watch?v=5NYe21nFSDI
          • panoss
            • Mar 2014
            • 35
            • Greece
            Maybe the flashrom is too slow?
            It didn't show me any error, verification went fine (according to flashrom).
            So you 're saying that most probably something went wrong with flashing?
            • peste
              • Dec 2016
              • 13451
              • ROMANIA
              i don't know what you did !!! it takes 5 min to write and read a bios chip ...
              • peste
                • Dec 2016
                • 13451
                • ROMANIA
                I sent you a video ... did you see it?
                • panoss
                  • Mar 2014
                  • 35
                  • Greece
                  Yes I saw it.
                    • 21692
                    Try ASProgrammer software, it should take less than a minute to program. https://www.badcaps.net/forum/showpo...6&postcount=10
                    • panoss
                      • Mar 2014
                      • 35
                      • Greece
                      I tried it in a fast PC and indeed within 5 minutes the EEPROM was written.
                      So it was slow because I used a slow PC.
                      Now, the BIOS is ok (written, verified, 100% ok).
                      So, the problem must be in the Graphics chip. But. Which is the graphics chip?
                      Is it the one pointed by the red arrow in the photo?
                      • piernov
                        • Jan 2016
                        • 4437
                        • France
                        That's the southbridge.
                        The dead chip is usually the northbridge, under the heatsink next to the CPU.
                        Before you do anything crazy, do *NOT* attempt to reflow it. You can try to heat it a little bit (200°C MAX, no flux) for a minute and a half with hot air to see if it comes back to life. This is not a fix, it will fail again and it has to be replaced.
                        • panoss
                          • Mar 2014
                          • 35
                          • Greece
                          Ok, I found exactly my case: 5 blinks on Caps led, black screen:
                          https://www.youtube.com/watch?v=cxfGweTAdrQ
                          • piernov
                            • Jan 2016
                            • 4437
                            • France
                            This is a great example of a misleading video, like there are dozens if not hundreds on Youtube.
                            • panoss
                              • Mar 2014
                              • 35
                              • Greece
                              Ok, I won't do excactly what he does. I won't go above 200 Celcius, and this for just a few seconds. I will not reflow it.
                              • panoss
                                • Mar 2014
                                • 35
                                • Greece
                                Well...it worked!!
                                I did heat it (no reflow, just heat) with a heat gun, reassembled and it works!
                                I didn't expect this to succeed!
                                Now, how long will this keep working, I don't know.
                                Maybe hours, maybe days, maybe months?
                                • Filipksif
                                  • Aug 2022
                                  • Serbia
                                  I also have a problem with the caps lock flashing 5 times. I suspected the bios chip. When I tried to reprogram it, the program threw me: content on the chip are disagreement. I don't know how to write back to the chip the old dump I saved before I wiped everything from the chip. I use ch314a and as programmer.
                                  • peste
                                    • Dec 2016
                                    • 13451
                                    • ROMANIA
                                    post the original bios... try one of these programs...
                                    https://www.badcaps.net/forum/showpo...04&postcount=7
                                    • Filipksif
                                      • Aug 2022
                                      • Serbia
                                      I managed to program the chip. Now when I try to start the laptop with the chip programmed it won't start at all. Only the lan lights are flashing.
                                      • SkyLine Computers
                                        • Feb 2023
                                        • Sri Lanka
                                        Try this
                                        Thanks This is working
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • maanee11
                                          Help to get Lenovo BIOS bin file for Thinkpad T560
                                          by maanee11
                                          Hello Everyone,
                                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                          05-15-2022, 11:59 AM
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
