840 G3 Bios request
  • slaine
    • Feb 2020
    • 21
    • germany
    840 G3 Bios request
    Hi All,
    in the process of trying to remove the Bios-PW from an 840G3 I somehow F´d up and got a bad Dump. Leaving me with a broken state (power led just flickering or reboot loop with high fan speed and reboot).
    I already tried differnt dumps found in this forum, no luck.
    It looks like those are for the 6050xxx type Mainboard. Mine is a 6070B0883301-A02. If anyone got a clean Main-BIOS dump (16MB) and maybe the EC dump (~8MB) i would be very thankfull if someone could upload it for me to test.
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: 840G3 Bios request
    Post your bios backup here
    • slaine
      • Feb 2020
      • 21
      • germany
      Sorry, the dump is only FF´ed trough the whole area, i think I blew the eeprom while inserting it into the reader (never change the prom while still connected to usb... )
      So I would need a complete cleanME unlocked dump for this machine - MB reads 6070bxxxxxx instead of the 6050xxxx type.. any help appreciated (I cannot even get the prom to read anymore, i ordered a empty one already)
      • Oday91
        • Oct 2022
        • Sweden
        hi i have the same motheboard did you get any help, i also need clean bios file to delet bios admin password without removing the chip.
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          the bios chip must be removed from the motherboard before reading or writing, or soldered wires between the chip and the programmer, after which we post the bios here...
          https://www.youtube.com/watch?v=DWWigscuQDY
          • Oday91
            • Oct 2022
            • Sweden
            thanks for the answear, is there anyway to remove it whiout need to open the laptop ?
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              it's not possible.. you got the answer above..
              • swiniks
                • May 2025
                • 3
                • Ukraine
                Please help me remove the BIOS password
                HP EliteBook 840 G3
                Mainboard : 6070B0883301 rev: 1.02 A02
                Damp Lock Pass: Yes
                Download BIOS
                • danito
                  • Jun 2016
                  • 1259
                  • Romania
                  HP EliteBook 840 G3
                  Damp Lock Pass: Yes
                  Download BIOS
                  No external links and do it yourself https://www.badcaps.net/forum/troubl...locker?t=98539
                  • swiniks
                    • May 2025
                    • 3
                    • Ukraine
                    Sorry, I couldn't find another way to post the dump. Unfortunately, RCUnlocker doesn't know such a BIOS and Unloker doesn't solve the problem either. Can anyone help?
                      • 22293
                      I have added the file to your post. Your file is 16385KB ,it should be 16384KB ,i suspect that`s why the patcher didn`t work. I think you chose an OTP chip instead of the non OTP ,and that`s why the extra code was added.
                      • swiniks
                        • May 2025
                        • 3
                        • Ukraine
                        I didn't quite understand, I throw the firmware into the exe file RCUnlocker_v_1_0 and get an error message. Firmware size 16.0 MB (16,777,984 bytes)
                        Click image for larger version  Name:	2025-05-07_12-53-04.png Views:	0 Size:	40.2 KB ID:	3631424
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
